AHA-Lambda
Hi, looking for thoughts on this build.
CORSAIR FRAME 4000D RS ARGB MODULAR - WHITE
32GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 16GB)
16GB SAPPHIRE PULSE RADEON™ RX 9070 XT GAMING - 2 x HDMI, 2 x DP
1TB SAMSUNG 990 EVO PLUS M.2, PCIe 4.0 & 5.0 NVMe (up to 7150MB/R, 6300MB/W)
CORSAIR 1000W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
5 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD 2.5Gbe LAN PORT
Home Installation
Technician Assisted Installation & Set-Up
Price: £2,355.00 including VAT and Delivery
www.pcspecialist.co.uk
I’m feeling:
- quite set about the GPU choice
- pretty good on the CPU, RAM, and storage capacity choices
- but a lot of the rest I’m kinda guessing/flexible on from PC Specialist’s options (especially feeling unsure about the mobo or cooling, and I’m open to increasing the ram to 64gb unless that is overkill?).
I don’t know much about PC building so appreciate the help, thanks!
(Not sure what to do with a monitor yet, I’ve got an old Dell 27” 1440p monitor that I expect I’ll replace later in the year)
Home Installation
PCSPECIALIST - Configure the AMD Am5 PC to your ideal requirements.
PCSpecialist is an award-winning manufacturer of high quality custom PCs & Laptops. Configure the AMD Am5 PC to your ideal requirements.
I’m feeling:
