I need a PC to run GTA V that will be coming out soon.
CORSAIR 230T COMPACT GAMING CASE - RED LED + SIDE WINDOW
Intel® Core™i5 Quad Core Processor i5-4590 (3.3GHz) 6MB Cache
Gigabyte H81M-D2V: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
1st Hard Disk
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Price: £799.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/vrQqSu5LOM/
ok, but is it possible to add other RAM or graphic card?
up to 16gb with either, no extra GPU with any of the motherboard you mentioned. If you click on the interrogation sign next to the components on the configurator it gives you further information.
A314159
Super Star
If you want to upgrade in the future, get the z97 hd3. More expensive but probably worth it, ATX as well so fits the case better.
Spuff
Expert
ths, so this we max out GTa V right?
What you can be assured of is that with the GTX 770 you will get the improved graphics compared to the PS3 and XBox 360, with a decent frame rate.
I'm playing AC Black Flag at the moment and even with my GTX780 Superclocked it doesn't maintain 60 fps all the time even with a couple of settings not at max (although anything above mid 40's fps is fine to my eyes).
So it really depends on how far a game lets you push the settings as to whether you can go at max settings at an acceptable frame rate. Sometimes you can take settings up to a point where they use a lot more power for little noticeable benefit, so sometimes you are not losing out on any difference you would notice by not being at total max.
