BenWoodcock520
Hi
I have received my new PC build (spec below) and for the first day it was running just fine.
Today, however, the side fans are going absolutely crazy. I have attached images showing iCue displaying my "sensor 3" on my GPU is 255 degrees. I have also attached one showing the fan speeds.
I know the sensor 3 issue is a known issue as the 5090 does not have a sensor 3.
But how can I make the machine usable ? Currently it sounds like a jet engine.
I reinstalled the iCue software but it's still the same.
Please can someone suggest something ?
LIAN LI O11DYNAMIC EVO RGB GAMING CASE
AMD Ryzen 9 9950X3D 16 Core CPU (4.3GHz-5.7GHz/128MB w/3D V-CACHE/AM5)
64GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 32GB) KIT
32GB ASUS TUF GEFORCE RTX 5090 GAMING OC - 2 x HDMI, 3 x DP
4TB CORSAIR MP600 PRO NH NVMe PCIe M.2 SSD (up to 7000 MB/R, 6500 MB/W)
CORSAIR 1200W HXi SERIES™ ATX 3.1 & 5.1 PCIe MODULAR 80 PLUS® PLATINUM V2
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
LED Lighting
2 x 50cm ARGB LED Strip
4 x Corsair ICUE LINK RX120 RGB PWM Fan + Controller Kit
ONBOARD 2.5Gbe LAN PORT
Firefox™
Cable Management
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
Miscellaneous
PCSpecialist 2023 Holo Sticker Sheet
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
Original Case Packaging
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/95cJpZ0Ng0/
Thanks,
Ben
LED Lighting
Firefox™
Cable Management
Miscellaneous
Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
Thanks,
Ben
