Initia keyboard led backlight
JeffL
I'm not sure if this is a Linux matter or not.
Fn key access to the keyboard leds does not work on my 15.6" Initia (Clevo NL55PU Model B with Linux Mint 21.3 installed). On my old Clevo laptop (P150EM Model A), using the Fn key with key * (on the numeric keypad - above key 9) would turn the leds on or off, and using Fn with the keypad + or - keys would increase or decrease the led brightness. From the manual for the Initia, the same should happen, but it doesn't. Is the new model dependent on the Windows Control Center being installed? I noticed that, when booting, the leds would slowly change colour before returning to a steady blue, so assumed keyboard led control was within the Bios as I don't have Windows installed. If that's the case, why does the Fn key not function with the led control keys on the numeric keypad? I couldn't see anything in the manual relating to the Insyde Bios about accessing the keyboard leds, and I'm always reluctant to play with the Bios as it's too easy to screw something up! (As an aside, am I the only one to find the old Dos-style Bios a lot clearer and simpler to use than the Insyde Bios GUI-style interface?)
(For the specs of the Initia see my post 'Mint 21.3 Edge installed on 15.6" Initia')
On a related matter, has anyone installed the Novacustom Linux led control system? It seems to be based on the Tuxedo, but says that's no longer available for non-Tuxedo laptops.
<https://novacustom.com/clevo-keyboard-backlight-control-for-linux/?>
Jeff
JeffL
Is this a pcspecialist laptop? Can you post your full specs from the order page?
Yes, delivered last Saturday.
Specs:
Chassis & Display Initia Series: 15.6" Matte Full HD 60Hz 45% NTSC LED Widescreen (1920x1080)
Processor: (CPU) Intel® Core™ i5 10-Core Processor i5-1235U (3.3GHz) 12MB Cache
Memory: (RAM) 16GB PCS PRO SODIMM DDR4 3200MHz (1 x 16GB)
Graphics Card: Integrated Intel® Iris® Xe Graphics (DUAL CHANNEL RAM) OR Intel® UHD Graphics (SINGLE CHANNEL RAM)
1st M.2 SSD Drive: 512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW)
External DVD/BLU-RAY Drive: 8x Slim USB 2.0 External DVD-RW
Memory Card Reader: Integrated Micro-SD Memory Card Reader
AC Adaptor: 1 x 45W AC Adaptor
Power Cable: 1 x 1.5 Metre Cloverleaf UK Power Cable
Battery: Initia Series Integrated 49WH Lithium Ion Battery
Sound Card: Intel 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless: GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 + BT 5.0
USB/Thunderbolt Options: 1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
Keyboard Language: MULTI COLOUR BACKLIT UK KEYBOARD
Operating System: NO OPERATING SYSTEM REQUIRED
Operating System Language: United Kingdom - English Language
Windows Recovery Media: NO RECOVERY MEDIA REQUIRED
Office Software: FREE 30 Day Trial of Microsoft 365® (Operating System Required)
Anti-Virus: NO ANTI-VIRUS SOFTWARE
Browser: Microsoft® Edge
Notebook Mouse: INTEGRATED 2 BUTTON TOUCHPAD MOUSE
Webcam: INTEGRATED 2.0 MP FULL HD WEBCAM
I had a look at the Bios but couldn't see anything relating to the keyboard led lighting.
Jeff
Yeah, control center is required in windows. Until that’s installed it won’t work properly and even things like cooling will be sub optimal. But control center control the rgb (as well as everything else)
If you’re on Linux, I believe tuxedo stuff is compatible from what I’ve heard.
There’s also SignalRGB and OpenRGB but not sure if they have Linux versions yet.
JeffL
Jeff
I can confirm that this does allow control of the keyboard led lighting. Disable UEFI/Secure Boot and run this in a terminal:
wget https://github.com/wessel-novacustom/clevo-keyboard/raw/master/kb.sh && chmod +x kb.sh && sudo ./kb.sh
Reboot. After installation, to clean up the installation folder and file run:
sudo rm -rf clevo-keyboard
sudo rm kb.sh
Re-enable UEFI/Secure Boot if required.
Note that the Fn key, together with the */-+ keys on the number pad, now allow the led lighting to be turned on or off (Fn and *), the led colours to be run through and selected (Fn and /), and the brightness to be changed (Fn and + or -).
Jeff
