is my desktop/gpu over heating?
xuiton
So I bought my desktop from here in the summer of 2010 and I'm still very happy with it. However, over the past couple of months, the computer has started crashing.
The screen would go off and display a message as if it had lost power, yet the computer still sounded like it was running. This would only happen while playing games. Has happened the odd time on alot of games I have, happened frequently enough on old mass effect one for some reason. I make sure v sync is always on to stop the computer working harder than need be but it can still happen. I use a gtx 480 which I know is an extremely hot card and usually runs at 90c even nearly 100c alot of the time.
Although I have added another 6gb of ram, but I had this problem before the ram upgrade.
here is the specs.
Case PCS MAELSTROM T900 BLACK GAMING CASE (£59)
Overclocked CPU OverClocked Intel® Core™i7 Quad Core Processor i7-930 (2.8GHz @ max 3.8GHz)
OC Settings Show/Hide
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 6GB KINGSTON HYPER-X TRI-DDR3 1600MHz, INTEL X.M.P (3 x 2GB KIT)
Graphics Card 1536MB NVIDIA GEFORCE GTX480 GDDR5 PCI EXPRESS - DirectX® 11
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 640GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
1st Hard Disk Partitions 640GB, GB
2nd Hard Disk 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
2nd Hard Disk Partitions 500GB, 500GB
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply CORSAIR 850W PSU (TX850) 80+ ULTRA QUIET (£100)
Processor Cooling TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Thermal Paste ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Office Software FREE Microsoft® Office Starter 2010 (Limited functionality Word & Excel)
Monitor NONE
2nd Monitor NONE
DVI-D & HDMI Monitor Cables 1 x 2 Metre DVI Cable (£5)
Eyefinity / GeForce 3D Vision NONE
Keyboard & Mouse NONE
Mouse NONE
Speakers NONE
Webcam NONE
Headsets NONE
Surge Protection NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Silver Warranty (1 Year Collect & Return, Lifetime Tech Support) (£5)
Home Installation NONE
Data Recovery NONE
Build Time Standard Build - Approximately 7 to 9 working days
Miscellaneous FREE Just Cause 2 Game (RRP: £34.99) with any GTX 4xx Series GPU!
I got this message after rebooting to windows.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA801017C4E0
BCP2: FFFFF88006353F60
BCP3: FFFFFFFFC000009A
BCP4: 0000000000000004
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
vanthus
Member Resting in Peace
Could be the GPU is overheating as you say,try running a temps monitor app like GPU-Z to check.
Might be worth giving the PC a dust clean out as well if you haven't done so for a while.
xuiton
yeah I have a temp monitor running. when not using a programme such as a game, such as on this forum, my gpu will sit at 60c but in games around 90 which i'm aware of is apparently normal for a 480.
Yeah already cleaned in the other week.
