MJSWARLORD
i have been geeking since 2003 and the only pc i ever got system restore you work on was xp , maybe i am just unlucky... i now have the same problem with both a shop bought pc and a pc specialist built rig both running windows 10 ..
i got the op system on disc for the custom built rig.....
i made a recovery program on a usb pen just in case the windows creator program caused me any problems.... the 3 options to use it are , refresh pc without loosing files , automatic repair and reset pc...
as sys restore wont work could i use the refresh option as a type of system restore and make a newer version of the recovery pen every so often.
