Laptop does not show any wifi networks
allils
This one has baffled me. I have never got a laptop that doesn't show wifi networks. Am I missing something here because without wifi this is not really a useful machine :/
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
32GB Corsair 2133MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® GTX 1660 Ti - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
Choose from 6 Incredible Ubisoft Titles FREE with select SAMSUNG SSDs!
256GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
Integrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor
1 x 180W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
Bluetooth & Wireless
PER-KEY RGB BACKLIT UK QUIET MECHANICAL KEYBOARD
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
Chassis
TongFang GK7CP6S (6GB GTX-1660 Ti, i7-9750H, 144Hz)
allils
Nope, everything is fine. Even the network adaptors show up. I also tested by plugging in a wired connection and it works fine with that. Sadly though I do need the wireless because of my limited facilities
It’s possible the antenna aren’t connected properly inside the case. I would raise it with PCS at any rate. If you feel comfortable taking that case apart then usually it’s quite easy to locate the WiFi module. I’m not familiar with that chassis, so can’t guide unfortunately.
allils
OMG I don't believe it was that. Why was that not connected?. It says that they test before sending the machines out. Thank you for suggesting it, works fine now cause yes it was not connected :sleep:
Well, that is naughty, not sure how that made it passed qc, but an easy fix! Glad it’s working!
