Lecturer working from home
Hi folks,
I'm a university lecturer, doing lots of teaching at home at the moment. I've been surviving on a 5 year old Lenovo Yoga laptop with single core processor. It's been a struggle at times running essential programmes while on Zoom video calls.
I'm not looking for a gaming PC, but to be able to do some basic stuff:
- Typical working day, to be able to use Outlook, Word, Powerpoint and a browser while on a Zoom video call. My laptop creaks when I do this!
- Occasionally some basic audio and video editing, using Audacity and Kdenlive.
- I have a 2TB external SSD which I use for data backup
I don't know much about computers, but figured the specifications I could put together in a custom built PC here were better than something off the shelf from Currys. The build below comes out at around £600, and that's pretty much my budget. But for all I know, the combination of components might be nonsensical. So I'll be very grateful for advice on the specs below.
Thanks,
Adam
PCS 3312B BLACK CASE
Intel® Core™ i5 Six Core Processor i5-10400F (2.9GHz) 12MB Cache
Gigabyte H410M H V3: Micro-ATX, DDR4, USB 3.2, SATA 6GBs
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
1GB NVIDIA GEFORCE 710 - DVI, HDMI, VGA
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
PCS 250W 80+ BRONZE POWER SUPPLY
STANDARD CPU COOLER
BullGuard™ Internet Security - 3 User, 1 Year
Standard Build - Approximately 16 to 19 working days
Price: £594.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-III/KCCBsVRy2z/
Ooh should have added that I will use a couple of monitors, one of which has VGA and the other HDMI, hence the choice of graphics card. Hope that makes sense..
Some helpful hints Especially the amd vs intel thread
Thanks - I read all that. Couldn't change the processor to AMD without starting the whole thing again, so I left it as was. Presumably the Intel processor will do the job well enough though given what I'm using it for..?
sck451
I'm going to give an alternative option here, because I'm really not a fan of your spec there. It'll work, but I'm not convinced it's value for money. In particular, that graphics card is pretty woeful (I'm not sure, but you may even be better with the standard 10400 non-F and just using the integrated graphics).
It'll last a couple of years, but I expect it will then start getting very tired and you'll have no real capacity to upgrade it.
For £200 more, you can get something that ought to last a good five years, probably more, and which could easily be upgraded in future.
This is an AMD build using the 5600G CPU with its integrated graphics. For your work it really is streets ahead of your original build.
If you really can't go that high, I'd at least want to switch to the integrated graphics solution, and upgrade the case and power supply, which will help enormously with longevity.
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4)
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
STANDARD AMD CPU COOLER
Price: £802.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/MJSyrKfyRr/
Nymor
I'm a non-gamer too and needed a new work PC with dual monitors and have just taken delivery of a very similar build to the one suggested using the 5600G - but with a bigger power supply (for possible later upgrades), and 2nd slower HDD (SSD for W10 & programs - HDD for data) and a surge protector 6 gang (just because) and different case.
FRACTAL FOCUS G BLACK GAMING CASE (Window)
Surge Protection
6 Socket 2m Surge Protector
Promotional Item
Get a Warframe: G-Series Pack with select AMD Ryzen G-Series CPUs
Welcome Book
Logo Branding
PCSpecialist Logo
Price: £888.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/T2FawCn4NX/
You'd have to get a displayport to vga cable/converter as the outputs are hdmi and displayport but that's of no consequence.
I think you're looking at a budget of £800+ whichever you go but you'll get something that will last.
Thanks for all this great advice. I'll have a proper look at the suggested specs later today. Just to clarify, I haven't ordered yet - when I said I couldn't change the processor I just meant in the existing build quote. Budget can stretch 200 but I guess I just didn't see the point in paying loads more. Sounds like that might have been false economy, from the advice I've read here. I'll post later - thanks all again.
Adam
Adam
Phew.....................that makes life a lot easier
Many thanks for this. I'd really appreciate some points explaining that I have no clue about:
1. Why are the case and power supply are worth upgrading? Those two make £72 difference, but it would never occur to me that they were useful investments.
2. I take the recommendation of AMD over Intel, but will the setup you recommend, with the graphics built into the processor, support two monitors?
3. You recommended 3200MHz RAM over the 2400MHz RAM. Where will I see that £29 difference?
Again, thanks for your time and suggestions, it's very much appreciated.
Adam
sck451
Adam
1. Case and power supply are really the foundation of the build. A poor case will cause high temperatures, which will reduce performance and possibly diminish the lifetime of the build. A poor power supply (and an own-brand 250W is about as low-grade as you can get these days) will be noisier and less efficient, limit any potential future upgrade, and be much more likely to run into reliability problems down the road. I wouldn't want to skimp on either of these areas.
2. Yes, no problem. The Prime B550-plus has one HDMI port and one DisplayPort, so you may conceivably need to get an adapter, but it'll work fine.
3. In all areas of performance. Slow RAM will diminish the performance of both CPU (AMD CPUs want fast memory: anything under 3200MHz will result in a degraded CPU performance) and the iGPU (as the RAM acts as video memory). In video editing, this will be a whole world of difference, but also in multi-tasking.
Basically the principle is to get a solid foundation for the build, so it performs well now and can also face upgrades in the future. For example, you could stick an RTX 3060 in this build and have a very strong video editing system.
OK thanks very much for all your advice. I've ordered the setup you recommended. If it's rubbish, I'll know who to blame 😂
So my computer arrived on Wednesday and all is good. Everything very fast and nicely set up. Looks great with my big screen, and I'm just waiting for Amazon to deliver a DP-VGA converter so I can hook up my second screen. My question is - what is all this stuff that was packaged neatly in a box for me. I managed to spot the screw-in aerials for my wifi and bluetooth in there, but I have no idea what the rest is. Are these things I need? Should I be using them somewhere? Should I keep them safe? Any advice gratefully received. Thanks!
sck451
They're all the spare accessories, like extra cables that came with your power supply but that you don't need right now. Keep hold of them in case you need them in the future.
Pics and a review would be great when you can!
TYVM, I've put everything away safely.
One issue I've been having is with my internet connection. I'm connected with wifi, and it's horrendously slow. I have just been having a morning full of Zoom meetings with students and had to abandon after the first meeting and get my old laptop back out. I'm getting
0.25 Mbps download and 0.13 Mbps upload. My old laptop, in exactly the same location as the new desktop, is getting 26.5 download and 18.4 upload. Computer is about 4 metres from the router, with an internal wall in between. Does this sound like a configuration issue or something else?
sck451
I know you mentioned the antennae further up the thread, but are they attached properly? That's the most likely cause of WiFi issues. In addition, have you run Windows Updates? I realise it'll be quite slow, but there may be drivers that need installing.
I assume the antennae are in the right place. This is the only place that made any sense. I've set the computer to download and install the optional update that is available, as well as some driver updates it offered. I'll see what happens once those are done.
