NZXT H511 MID-TOWER GAMING CASE (WHITE)
Intel® Core™ i5 Six Core Processor i5-10400F (2.9GHz) 12MB Cache
GIGABYTE B560 AORUS PRO AX (rev. 1.0) : LGA1200, USB 3.2, PCIe 4.0, CrossFireX, Wi-Fi - ARGB Ready
8GB AMD RADEON™ RX 6600 XT - HDMI, DP - DX® 12
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
Corsair H60 2018 Hydro Series High Performance CPU Cooler
www.pcspecialist.co.uk
I'm thinking to swap one of the Intel M.2 SSDs to a 500GB SEAGATE FIRECUDA 520 GEN 4.
Is it possible to do even though it's already in it's 3rd day of processing?
Is it even worth doing?
The total cost is cheaper than two 1tb intel SSDs when I swap one of them with a 500GB SEAGATE FIRECUDA 520 GEN 4, so technically I would lose some money unless PCSpecialist is able and happy to pay that back.
I noticed there is an option to "upgrade your existing pc specialist computer" which I can only use once it arrives. Would I have to pay the total cost of the an upgrade, or would it be reduced by the cost of the item I'm upgrading? (e.g. GPU being £500 and the upgrade GPU being £800, so a £300 upgrade fee instead of paying full £800). This is assuming PCSpecialist would take the item you're attempting to upgrade.
I'm someone that's looking to do some hardcore gaming and possibly streaming/content creation in the future.
Any advice would be much appreciated.
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
