My current PC is getting too old (2011 from PCS) so it's time to replace it.
But I have a few drives I want to take to the new PC.
90% of the time will be Lightroom/Photoshop, and then some office work.
Key parts of the spec I am looking at ...
Case CORSAIR 175R RGB MID TOWER GAMING CASE
I need a smallish case that will accommodate 2x2.5" + 2x3.5" drives
Processor (CPU) Intel® Core™ i5 Six Core Processor i5-10600 (3.3GHz) 12MB Cache
Motherboard ASUS® TUF GAMING B460-PLUS: ATX, LGA1200, USB 3.2, SATA 6GBs - RGB Ready
Memory (RAM) 32GB Corsair VENGEANCE DDR4 2666MHz (2 x 16GB)
Graphics Card 6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
Power Supply CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
To make sure the additional drives will be ok
Processor Cooling PCS FrostFlow 100 RGB Series High Performance CPU Cooler
The PC will go under a desk so lightintg is not important. I May switch to the Black cooler.
Now to the storage -
1st M.2 SSD Drive 512GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
OR the PCS 512GB SSD
So Windows 10 would be installed on this device. With a single partition.
I have never used M.2 SSD's before so a few questions...
- Can I have just one M.2 device and no other drive?
- Can I boot from the M.2 drive?
- Are they reliable?
- As they're SSD, do they have the same NAND memory? and areTBW figures comparable to SATA SSD's? Can I find figures?
I have a SandiskPro-240 at the moment. Installed for 2.5 years and down to 75% life so it should last another 7.5 years if used at the same rate (in theory)
Anything else I should know about M.2 SSD's ??
This is the spec of my old PC so the new one should be a 'bit' faster.
AMD Phenom II 964 (4 core)
8GB RAM
HD 6570 Graphics
240GB SSD and a variety of HDD's
8GB RAM
HD 6570 Graphics
