Microsoft Flight Simulator 2020 - PC Spec
Hello, I am looking at putting together a pc purely to run MFS 2020, and am hoping to get close to the recommended specs on a budget of less than £900 give or take.
Microsoft Flight Simulator recommended specs
CPU: Ryzen 5 1500X / Intel i5-8400
GPU: Radeon RX 590 / Nvidia GTX 970
VRAM: 4GB
RAM: 16GB
HDD: 150GB
Bandwidth: 20 Mbps
Microsoft Flight Simulator ideal specs
CPU: Ryzen 7 Pro 2700X / Intel i7-9800X
GPU: Radeon VII / Nvidia RTX 2080
VRAM: 8GB
RAM: 32GB
HDD: 150GB (SSD recommended)
Bandwidth: 50 Mbps
I intend to HDMI the pc to the TV so no monitor required.
This is the spec I have put together-
PCS 6003B BLACK CASE
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
STANDARD AMD CPU COOLER
LOGITECH® MK270 WIRELESS KEYBOARD & MOUSE COMBO
Standard Build - Approximately 21 to 23 working days
I am not particularly knowledgeable about these things but this appears to bring me in under budget. Please could someone let me know if this spec works and will run the sim at the recommended spec level? I opted for no wireless network as the pc will be located next to the router, so ethernet would be fine?
Thank you.
Could you provide the unique URL from the bottom of the listing. When you click continue you can then click "Post to forum". You can then copy and paste the entire list including the link etc from the bottom. Makes going in and proposing suggestions far easier. Otherwise we need to start from scratch.
I wouldn't recommend the following:
Case - Not good for airflow
Motherboard - Short lifespan
RAM - Too Slow
SSD - You want an M2 drive
PSU - Doesn't allow for upgrades and is a cheaper option, 550W TXm normally recommended.
AV - Standard defender is the best option. Bullguard and others are more intrusive than anything and don't offer any other safeguards.
Warranty - Silver warranty is only £5 and well worth it.
The following would be a pretty good build for current and future potential :)
CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
Price: £965.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/qrzgj2nQgr/
