Mid-range 1080p 60fps build help.
clancy2k
Hello, i'm looking to get a mid-range gaming pc for 1080p 60fps gaming. I'm looking at both options from Nvidia and AMD and I'm having trouble deciding what to go for!. I haven't bought a new pc in a few years so i'm out of the loop on what's the best value/performance for a mid-range gaming pc. I have made a couple of builds for around the same price (Nvidia build slightly more) and i'd like some advice on what would be best overall gaming performance. Here are the builds:
Intel/Nidia build:
CPU: INTEL® Core™ i5-6500 Quad Core 3.20 GHz
HDD: 1TB Seagate Hybrid Gen3 SSHD
MEMORY: 8GB HyperX Fury DDR4 2133Mhz
MOTHERBOARD: ASUS Z-170P
GPU: NVIDIA GeForce GTX 960 4GB
PSU: Corsair 450w
AMD build:
CPU: AMD FX-8320 3.50 GHz Eight-Core
MEMORY: 8GB HyperX Fury DDR3 1600Mhz
MOTHERBOARD: Gigabyte GA-970A-DS3P
GPU: AMD Radeon R9 380X 4GB
PSU: Corsair 550w
Thanks in advanced.
Cadwah
Rising Star
Personally I think the Intel/Nvidia build is stronger however you could shoehorn a GTX970 into a build for approx £700 which would give you better FPS than either of the builds you posted. There is of course a trade off in other components but you can always add an SSD at a later date...
CORSAIR SPEC-03 COMPACT GAMING CASE - RED LED
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s)
8GB HyperX FURY DUAL-DDR3 1600MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - DVI, HDMI, mDP - 3D Vision Ready
Free Item
FREE RAINBOW SIX OR ASSASSINS CREED with select GTX 9 Series GPUs!
1st Hard Disk
Super Quiet Titan DragonFly Heatpipe AMD CPU Cooler (£19)
Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
Price: £714.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-bulldozer-top-spec-pc/_I8fhH_xJK/
clancy2k
Free Item
1st Hard Disk
Thanks for the configuration. Will the GTX970 run well with the fx-6300 without any bottlenecks?
Cadwah
Rising Star
I would say that they would work well together, but obviously it depends on the game, games which heavily rely on the CPU like ARMA3 might give you some bottlenecks but it's nothing that can't be fixed with a slight overclock.
