MS 2020
mekd40
Been out of PC gaming and Flight Sim for a long time!
Would these specs be OK for the upcoming FS2020 running at a decent/ideal setting?
Don't really want to go much further than £2K.
Intel:
PCS SPECTRUM RGB MID TOWER CASE
Intel® Core™ i9 Eight Core Processor i9-9900 (3.1GHz) 16MB Cache
ASUS® PRIME Z390-P: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready!
32GB Corsair VENGEANCE DDR4 3000MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
LED Lighting
50cm Red LED Strip
Creative Sound Blaster® Audigy™ FX OEM
Monitor
Samsung LC24F390FHUXEN Curved 24"
Standard Build - Approximately 16 to 18 working days
Promotional Item
Get Rainbow Six Siege: Gold Edition with select NVIDIA GeForce RTX GPUs!
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/fNZdFK2udU/
AMD:
32GB Corsair VENGEANCE DDR4 2400MHz (2 x 16GB)
PCS FrostFlow 100 V2 Series High Performance CPU Cooler (AMD)
Monitor
Price: £1,966.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-workstation/6vRKSnbN0e/
Cheers M
mekd40
Thanks for the reply. I ideally want to run at top settings for smooth performance.
I will have a look at the set up you have suggested.
Thanks again.
M
Thanks again.
M
The key is top settings at 1080p. Resolutions are not created equal and thus need different power. The ideal/high settings quoted from M$ more refer to the resolution than anything else.
You can have ANY GPU on its knees with unrealistic settings. If you have in mind that the high spec recommendation for FS2020 is for 4k gaming, you won't go wrong.
2070 Super with a 1440 monitor is going to be significantly better than any 1080p setup. The fidelity alone with the resolution will make the 1080p look silly.
