My Current build spec.
Insane.Pringle
Intel® Core™ i5 Six Core Processor i5-10600K (4.1 GHz) 12 MB Cache
ASUS® ROG STRIX Z490-F GAMING (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
Welcome Book
Logo Branding
PCSpecialist Logo
Price: £1.877 including VAT and Delivery
usage will be primarily strategy games ie stellaris, Total war with some multimedia
i will not need a monitor as it'll be connected to my LG OLED55CX5LB (2020) OLED HDR 4K Ultra HD 55inch TV
Deleted member 17413
Have a good look through the links in this post
You arent going to want that build.
Insane.Pringle
i know, was talking to Spyder and others in the new members forums before i posted the specs above..
This is what I'd suggest in an AMD spec, it's slightly over price wise, but you're getting significant performance improvements and upgradeability down the line:
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) Far better processor all round
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Better PSU, semi passive so fan only comes on when under extreme load, leads to quieter operation, plus better stability.
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 Have added wifi and bluetooth card, your previous spec didn't have one, if you don't need it just remove.
Firefox™
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Price: £2,032.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/ufu2Mhqchq/
If you did choose to change it to AMD, you'd need to phone PCS and ask them if they can do it over the phone, as it's a different configurator, you can't do it online without cancelling your current build and reordering.
But PCS have switched for others over the phone before so it should be possible, and that shouldn't affect your place in the 3080 queue.
What refresh is the 4K monitor thats being used?
Am I right in thinking its a TV monitor, and 60Hz refresh? In which case a 3070 would be a good choice wouldnt it? 3080 seems like wasting money.
I did post to ask why Intel still, and have been told you have already ordered it. Best, honest advice I can give, is cancel.
Not trying to be harsh, but Intel and it looks like youve focused your budget into the wrong components, saccrificing in other areas to fit a 3080 in that I dont think you actually need....
Insane.Pringle
Hmm i think i'll be losing my place in the 3080 queue, i'm hard of hearing and cannot use the phones which is a bummer..
hmm don't know the refresh rate, i'll look it up but it's a smart tv, one the missus wasn't quite pleased at me getting but meh.
edit: just looked it up and it say VRR (Variable Refresh Rate)
You may be able to do it over the webchat or via email. Email will take around a week for a response. Web chat may be quicker if they answer, you may have to keep refreshing it to get a CS agent.
That's very likely one of the newer 120Hz TV's with Freesync, both Samsung and LG do them and they're extremely good for gaming.
Insane.Pringle
Firefox™
i'll remove the wifi/bluetooth as it'll be ethernet cabling. ive never liked wifi for gaming. i know it's good for it but i trust ethernet more.
AleTax
Ethernet will always give a better experience, if you can it's certainly a better option.
Indeed it will. If OP isn't capable of having direct ethernet cause of router being far away and has a mesh router, he could buy a mesh repeater with ethernet port included, in that way he can have same experience as being connected directly to the router :)
Insane.Pringle
yeah. i live in a block of flats with 8 flats surrounding mine. i can generally pick up 10+ wifi routers on my phone never mind the other IOT things like my tv...
wifi is useful in house as you are unlikely fill up the bandwidth but in a block of flats....
If its 120MHz, then yeah, 3080 by all means.
I would still take the shot at getting an AMD build, it doesnt make sense to take Intel anymore. No idea when it might again.
Insane.Pringle
first time ive been called a ghoul.... lol
theres only the links to fb, insta youtube etc, no webchat
nevermind.. this is on my tablet... just looked via my phone and magically the contact us tab appeared.... no one available tho..
AleTax
Keep refreshing or just call them
Insane.Pringle
cant call them myself as i'm hard of hearing and cannot use the phones
however i'm going to get a relative to phone up on my behalf :D
do i just phone up and say i want to change my configuration? i have the amd specs above saved as a quote?
