My Dream Pc
pcpower
I love Pc specialist. I hear they are the best at building Pc's.
I am going to order this Powerfull Pc. This Pc will last me for years.
My Spec.
COOLERMASTER COSMOS 1000 SILVER SILENT CASE
Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
ASUS® SABERTOOTH Z77: USB 3.0, SATA 6.0GB/s, THERMAL ARMOR
4GB NVIDIA GEFORCE GTX 690 DUAL GPU - 3 x DVI-I, 1 x mDP
600GB VELOCIRAPTOR WD6000HLHX, SATA 6-Gb/s, 32MB CACHE (10,000rpm)
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
3rd Hard Disk
4th Hard Disk
SSD CACHE DRIVE
20GB INTEL® SSD 313 SERIES - SLC CACHE DRIVE FOR SYSTEM / 1st HDD
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
CORSAIR 1200W PRO SERIES™ GOLD AX1200-80 PLUS® GOLD MODULAR(£209)
COOLIT ECO II A.L.C ADVANCED LIQUID COOLER (£59)
Creative Sound Blaster Recon3D Fatal1ty Champion (£179)
Bigfoot Killer 2100 PCI-E Gigabit LAN Card - Max Gaming (£59)
Speakers
LOGITECH S220 2.1 SILVER/BLACK SPEAKER SYSTEM (£19)
3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour) (£135)
Home Installation
Technician Assisted Installation & Set-Up (£79)
Data Recovery
2 x Hard Drive Data Recovery Service - Protect 2 Hard Drives Against Failure (£55)
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Price: £3,247.00 including VAT and delivery.
Wolvo7
Hum is that actually what you plan to buy or this that a "dream" PC? I'd change a few things even though you went for the expensive stuff.
Why would you need 9.6TB of storage lol? I dropped one of the Caviar Green and replaced another with a Black, it's faster. I also replaced the Velociraptor with an SSD, much faster. If you need more storage you can always add another Green once you've filled up your 5.5TB (!).
You don't need the fancy sound card, unless you really want the control panel, and tbh with the speakers you're going for there's no point in having a sound card at all, unless you already have a great sound setup or good analog headphones. If you get USB headphones they won't use the sound card.
The bigfoot killer won't change anything don't bother with it, you may notice a slight difference in LAN parties but not over the internet.
Changed the case too this one has front USB 3.0 ports and looks better too imo, and I dropped the technician installation, if you can plug cables at the back of a PC you don't need it.
COOLERMASTER HAF-X FULL TOWER GAMING CASE
480GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
3rd Hard Disk
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£159)
Fan Controller
NZXT Sentry 2 Fan Controller with upto 5 Fitted Case Fans
Creative Sound Blaster Recon3D PCI-E Soundcard (£79)
Speakers
Data Recovery
Price: £3,234.00 including VAT and delivery.
lewi34444
ye i agree wit wolvo, the amount of storage memory you have selected i doubt anyone could fill up, i would consider saving some from the storage memory and go with an ssd
