My first PCS computer!
RogWal
This is my first purchase from PCS and I'm impressed by the order turnaround: specified an AMD 5950x processor, it was only 1 month from placing an order to receiving delivery, although I suspect that was partially due to my opting for an AMD 6800XT graphics card rather than an Nvidia 3080.
Only minor downside of the whole experience was the DPD courier (and therefore outside the control of PCS). The DPD delivery man evidently tried to carry the box on its end using just one handle, causing the handle to give way (not surprising considering the weight) and the box to drop. The corners on the opposite side of the box had been, to say the least, physically challenged. Damage to the box is below, and this being the Internet, I have included the obligatory banana for scale:
That said, the box PCS use is sturdy, and inside the computer is well protected with a good inch or two between the computer and the sides of the box. So, despite the box being dropped, the contents were undamaged:
Have to say, whilst the hinges of box do look like as though they are past their first flush of youth, it's good if PCS are reusing boxes (e.g. from returns) in this age of environmental awareness. As all PCS customers know, inside the box is a smaller box containing a bag of spare screws, washers, SATA cables, power cables, cables-whose-purpose-I-have-no-idea, and all the manuals for the components inside the PC. Plus a hand pouch in which to keep all those cables etc.
It's a nice touch, to say the least.
Need to remove the bag of foam, of course, from inside the PC which protects the graphics card. . .
. . . after which I had the first real view the inner workings of the PC:
Must admit, more than a bit awestruck at first (my last PC was a low end desktop from Mesh, 7 years ago), followed a few moments later by a "hmmm . . . judging by all those fans, I really don't want to be sitting next to something that sounds like a 1980's Lada trying to reach 40mph".
Need not have worried! Set her up, powered her on and she barely whispers. Powered her down after installing the Windows update, and fitted in a spare M2 SSD I have. Took a while to locate the slot on the motherboard - turns out it was in a tight space between the power supply and the graphics card, under a heatsink. Got to say, a bit apprehensive I might turn this PC into an expensive brick trying to get that SSD installed.
But here she is in all her glory, with the room lights off!
If anyone is reading through these forums, trying to decide from whom to buy a PC, I can wholeheartedly recommend PCSpecialist.
Gavras
Master Poster
Great write and lovely looking build.
rather jealous you got a banana with your build, I only received a Yorkie Bar with mine.
what case did you go for ?
That's better than the haribo that normally gets chucked in to packages i get from some of the cycling companies ;):ROFLMAO:
Gavras
Master Poster
I one received what was nearly half a box of them with an order lol.
It looked like someone had just filled my order with millions packets of haribo lol.
RogWal
Great write up, that card looks huge.
I'd drop PCS a quick email with photos of the box condition
Thanks, and yes it is huge. If there were issues starting up the PC and someone told me to try reseating that card, I would be a little reticent about touching it to be honest.
Will drop PCS a short email about the delivery, as advised!
RogWal
Cheers, @Gavras. Originally I went with a Corsair 275R case, but received an email from PCS stating that it was out of stock and do I want to choose another case as it was the only item stopping the build. Although I was resigned to a Jan/Feb delivery due to processor/PSU/GPU shortages, the prospect of a pre-Christmas delivery if I changed the case was too much to resist.
Tried to choose an alternative case that I liked, but the Configurator kept rejecting my choices as they couldn't accommodate the AIO cooler. In the end, I was literally going through each case in turn and working my way through them all until the Configurator was happy. Ended up with the Corsair Obsidian 500D SE. To be truthful, I wasn't paying attention to the case dimensions or features by this time, hence the rather slight surprise by the size, and the lights when she powered up the first time :LOL:
Gavras
Master Poster
I thought it looked like a 500D SE, a very good choice, even though I am slightly biased lol.
it’s is a lovely case.
Its beautiful
longdog42
Is that a Merc 319 that you got yourself? I thought they were only getting the reference cards from their suppliers?
RogWal
Aye, it would appear so:
The model number is: RX-68XTACBD9
I guess PCS is literally finding any card it can from suppliers.
