This is my laptops right now
On the second screen you could see how thin this laptop is comparing to a coke cork. Sorry for the bad quality of those images, taken from my phone.
Specifics :
So, lets being.
I really want to send a special thanks to the pcspecialist building team, because the time it took to order and get this pc was really short, and it took them only 5 working days, from order to receive the parcel passed only 1 week, which was really fast.
When i ordered my old optimus 13'' it took them 8 days, now it was 5, good job guys!
1. So lemme say something about the case.
Laptop is really thin and light for the parts it holds inside. it is as thin as my ultrabook 410u lenovo, but much lighter, and stronger.
The case is all black, aluminium on the back of the screen, on top of base, under its plastic and the screen frames are plastic as well. Laptop build feels really solid, like it was melted into 1 part, and despite what people says about this laptop, it does not bend that easly, even screen could hold the pressure of closing and opening it from any place you will hold it.
The design itself is AMAZING, pcspecialist laptop additionally does not have the ugly GIGABYTE logo on the back and the front part of the screen, this is a big + for them. It does not look like a 1 thousands pounds rig, however in a color it comes from pcspecialist it feels somehow elitists despite its clean design. Looks like a normal laptop, but you know it will do any job you will throw at it.
I didnt noticed any creacks or other sounds coming from the case when touching it, really well made case.
Screen is decent and sharp. 1080p on this is just enough, colors are magificient and the good brightness, nothing i could complain about really.
Touchpad is decent and works on the edges and corner. Speakers are ok, not the best just a plain ok, due to that these are located at 4 spots on the laptop, could be pretty loud, however the sound is not depth and could be better in my opinion.
2. Thermal and emissions.
I dont know why a lot of people says this laptop is loud during surfing on the internet/idle, because it is not. It is really quiet laptop, when i am not playing any games on it. Different if you play a games that requires some power, then it could get pretty loud indeed.
This a piece of technology hold the temperatures decently if you ask me. Im using my cooling pad with 5 fans and it cools it additionally. The areas where you hold your hands are cool even during a gaming session. The only spot where it is getting pretty hot it is on top of the casis, near hangs and especially the power button, it gets really hot there but not that much to bother you during gaming. CPU temperatures are reasonable during playing games and its temperature varies between 70 and 80 degrees. I guess the GPU has the same. GPU throttling is real in some games, if you put the graphics too high. Temperatures are not really that big comparing to the older version of this laptop (p32w v3), due to the better cpu that has been made in 14nm technology, it produces much less heat like the older model used to.
3. Performance.
What i could say about it.
I got SSD 850 evo samsung into it, 8 gb hyper x impact ram, gtx 970m and a i7-5700HQ cpu broadwell, it does the great job and i dont really know what it is cappable of. All my games on the highest graphics are running on 60 and more fps with v-sync enabled. With samsung SSD, windows loads really quick and the games pops up almost instantly, im really impressed of the samsung ssd performance and i recommend it for anyone who is looking for a fair and decent drive.
4. Overall.
If you are going to buy a razer blade pro laptop, forget about it and get this one, its cheaper, has a better CPU is much less problematic than razer, according to my friend opinion who has it and complain about laptop thermal problems.
Price is reasonable for performance packed into that small and really enjoyable design. Light, powerfull, small, those 3 aspects are the fine compromise found in this one.
If you are looking for a portable and fine laptop, it is the one you are looking for, seriously.
Of course you could buy a laptop with similar parts cheaper or a stronger one with the slighty bigger price, however if you are looking something like a macbook pro or razer blade laptops, this one is a fine and fair alternative from pcspecialist.
At the end i would like to apoligize if my grammar somewhere was goofy in this text, english is not my native language, but i am at the good way improving it! Thanks for read.
Specifics :
hassis & Display Defiance Series: 14" Matte Full HD LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™ i7 Quad Core Processor i7-5700HQ (2.7GHz, 3.5GHz Turbo)
Memory (RAM) 8GB KINGSTON HYPER-X IMPACT 1600MHz SODIMM DDR3 (1 x 8GB)
Graphics Card NVIDIA® GeForce® GTX 970M - 3.0GB DDR5 Video RAM - DirectX® 12
Memory - Hard Disk 500GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Memory Card Reader Integrated SD Memory Card Reader
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Sound Card Realtek 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® AC-7260 HMC (867Mbps, 802.11AC) + BLUETOOTH
USB Options 4 x USB 3.0 PORTS (1 x POWERED, 1 e-SATA COMBINED)
Battery Defiance 14" Series 4 Cell Lithium Ion Battery (61.25WH)
Power Lead & Adaptor 1 x UK Power Lead & 150W AC Adaptor
Keyboard Language DEFIANCE 14" SERIES BACKLIT UK KEYBOARD WITH NUMBER PAD
Operating System Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
DVD Recovery Media Windows 10 (64-bit) DVD with paper sleeve
Webcam INTEGRATED 1MP HD WEBCAM
Delivery PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Build Time Standard Build - Approximately 3 to 5 working days
Price £1,328.00
So, lets being.
3. Performance.
4. Overall.
