Hey, I've already set up an order for a desktop computer - which I plan on using as my gaming computer + my regular day-to-day usage computer.
My order is currently sitting in Pre-production (5th working day as of writing)
I don't have any concerns about my build but I've never ordered a custom build like this before. Just wondering if I should make any changes.
I had a few reads about saying thermal paste isn't needed with this cooling + I read that I don't need a wifi network card as the MoBo has one built on?
This is the kind of advice I need. Thanks. Should I swap the network card or remove it etc. etc...
FRACTAL MESHIFY C BLACK GAMING CASE (Window)
Intel® Core™i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
ASUS® ROG STRIX Z370-E GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE RGB DDR4 3000MHz (2 x 8GB)
11GB NVIDIA GEFORCE GTX 1080 Ti - HDMI, 3x DP GeForce - GTX VR Ready!
1st Hard Disk
1TB WD BLACK 3.5" WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
M.2 SSD Drive
500GB SAMSUNG 960 EVO M.2, PCIe NVMe (up to 3200MB/R, 1900MB/W)
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Corsair H110i Hydro Series High Performance CPU Cooler
LED Lighting
2x 50cm RGB LED Strip
ASUS PCE-AC88 AC3100 2100Mbps/5GHz, 1000Mbps/2.4GHz
I didn't have a budget when I first ordered it but anywhere between £2,000-£2,500 seems to be okay, if i had to have one.
1st Hard Disk
M.2 SSD Drive
LED Lighting
