Need quick help please ! The 14" SkyFire IV or The 15.6" Cosmos II !
Hello !
I'm kinda stuck between those two laptops and i need some quick advice please, as far as searched there isn't much reviews of the skyfire so i'm leaning a bit to the Cosmos.
So here is what i think right now :
The skyfire is cheaper, smaller and has the gddr5 gtx 850m which a little bit faster than the gddr3 (and also thanks to the low price i can go as far as to get it with the i7-4710mq). the one thing that worries me is the cooling, which i fear isn't quite that good in this one especially due to the size.
And concerning the Cosmos i've only read good reviews about it so far, it's size is ideal for me and there is also the fact that it can support two drive along with the dvd player. (and due to budget issues i can't afford the i7 in this one)
And i know that with this configuration the laptop is bottlenecked by the gpu before it began drawing full power from the cpu (i'm talking about gaming which i will mainly use the laptop for).
Here is The Cosmos
Cosmos Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™i5 Dual Core Mobile Processor i5-4210M (2.60GHz) 3MB
8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
NVIDIA® GeForce® GTX 850M - 2.0GB DDR3 Video RAM - DirectX® 11
Free Item
FREE £90 IN-GAME VOUCHER with GTX 650 / 750 /7000M / 8000M Series GPUs
Memory - Hard Disk
1TB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (12 €)
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N-7260 (300Mbps, 802.11BGN) + BLUETOOTH
Cosmos Series 6 Cell Lithium Ion Battery (48.84WH)
Power Lead & Adaptor
COSMOS SERIES UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
2 DAY DELIVERY TO FRANCE (24 €)
FAST TRACK 5 WORKING DAY DISPATCH (50 €)
Price: 879,00 € including VAT and delivery.
And Here is the Skyfire :
SkyFire: 14" Matte HD+ LED Widescreen (1600x900)
NVIDIA® GeForce® GTX 850M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
Ultra Slim 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Integrated 2 in 1 Memory Card Reader (SD, MMC)
2 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
SkyFire 14" Series 6 Cell Lithium Ion Battery
1 x UK Power Lead & 90W AC Adaptor
INTEGRATED 11.6"/14" MSI UK KEYBOARD
Notebook Mouse
INTEGRATED 3.0 MEGAPIXEL WEBCAM
Price: 837,00 € including VAT and delivery.
What do you guys suggest ?! which one should i stick with ?
(sorry about the disorder ) Thanks in advance :)
GeorgeHillier
Either chassis should be fine with cooling. They wouldn't allow you to put components in that will make it overheat.
What's your intended use and budget?
If you can only afford the skyfire with an i7-4710mq then go with that. You'll have double the amount of cores :)
Thanks for the reply.
I will use it mainly for gaming, and my budget is 900 euros max ! So cosmos with i7 is a no go.
I know i should go with the skyfire with i7 4710mq it's tempting if had only found some reviews about it x-)
I've read in a review that with the gtx 850m, having i5-4210m or i7-4710mq will change little to nothing when it comes to gaming performance. What do you think ?
Depends on the game, as games are starting to use more cores the best choice is an i7 since the mobile version of the i5 only has 2 cores. if you are spending so much on a laptop I would try to save a bit more and get the i7 or you could get a pretty high end desktop for that budget.
Desktop isn't really an option for me as i move around a lot xD
I guess i will go for the skyfire with the i7-4710mq.
Thanks guys !
Thanks guys !
Edd1e
I believe the Skyfire IV is the same chassis as the MSI GE40 so maybe a search on that for chassis comments might help you?
Other than that I would echo the comments on trying to get the best spec for processor for gaming as it will see you father in the long run.
Yep you're right @Jmrk1994 my bad.
Too bad the skyfire is no longer available, i guess i'm going to stick with the cosmos
Thanks guys.
