Never mind
N NiN393 Member Dec 20, 2022 #2 I think your choice of power cable is maybe a little bit 'overkill' and may outshine the other components? Seriously it looks high end and I'm sure it will fly👌✌ It will be interesting to see if it can handle 'Puzzle Car' maxed out🤔😉
B4zookaw VALUED CONTRIBUTOR Dec 20, 2022 #3 I'd get a case with better airflow, TD500 Mesh, Fractal Meshify, Lian Li 215, Corsair 4000D airflow, all better choices. And maybe look to upgrade PSU to 1000W in case you want to upgrade GPU down the line?
