New bios settings
Gr4
Hi i Have not been into a bios for a few years now and notice that the new motherboards have a thing called uefi !, Could anyone tell me the F key inputs to enter at boot or is it done another way now
It depends which OS you're on, if you're on windows 8, 8.1 or 10, then go to pc settings/update and recovery/recovery/advanced startup and reboot. If on windows 7 or below, then it's either f2/esc/f12 usually.
Gr4
Ah thanks, it will be win 10, So its now accessed through windows then reboot, Nice 1 cheers again
Warbloke
I got the X99 Gigabyte Gaming P motherboard on my new system delivered last week, and the INTEL 750 Series PCIe SSD, with Windows 10 - I can tell you I have more than enough time to enter the UEFI setup menu during boot up.
In my case, I have a choice of either 'F2' or 'Delete' to enter setup.
