New Case
rich1241
Hi folks,
I've got the following PC on order (now on 81 days 😬) & had an email yesterday to say the Fractal define 7 case is out of stock. Changed it to the CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE instead with 2 extra fans. Any issues with this case & my spec or any other better recommendations?
In case anyone else is in same boat, PCS did say when your machine eventually goes into building it's worth asking them if they have any Fractal in stock.
Cheers,
Rich
ASUSĀ® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
CORSAIR 850W RM SERIESā„¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
WIRELESS INTELĀ® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
FREE 30 Day Trial of Microsoft 365Ā® (Operating System Required)
Google Chromeā„¢
Promotional Item
Get CoD:Cold War & 1YR GeForce Now w/ select RTX Graphics Cards
Welcome Book
Logo Branding
PCSpecialist Logo
Steveyg
The Corsair 5000D is a better case to be honest, free upgrade mate. It has two extra bays for 2.5" drives and it's bigger with more room inside
fenderman
@Steveyg - I've got the same case on my order (Fractal 7) and have run into the same problem as Rich1241. Is the Corsair 5000D particularly noisy in comparison to the Fractal case as quietness was one of my criteria?
Steveyg
According to tests the 500D is 3Db louder than the Fractal 7 which is basically nothing
This is true for sound intensity but not for volume, the perception of sound only increases every 10 dB which is probably the most important factor.
