NEW Dayz patch!!
KaneMac
DAYZ PATCH UPDATE 5 FEBRUARY 2014 - Thought I would post the details encase Day Z fans have not seen the patch notes yet.
Branch: Stable
ETA: Complete
Version: 0.33.114926
Known Issues:
- Spawns: Loot is not spawning in military tents
- Spawns: Some structures in Svetlo currently do not spawn loot
- Server: Servers under load can delay actions from the client
- Graphics: Only 4 dynamic light sources will be rendered at one time currently
- Actions: Looting a dead body may make a ghost clone copy of the inventory
New:
- Actions: chambering SKS round from pile, loading 10 rounds from pile
- Actions: You can uncuff other players with the hacksaw
- Actions: Cannot use an item (e.g. drink/eat) if it is "Ruined"
- Actions: Interactions with items reworked. Drinking/Eating/etc... more robust and user-friendly
- Actions: Restrained players cannot use inventory or action menu
- Animations: Player now can take and hide rifle in crouched run
- Animations: SKS reload animations
- Animations: firing weapon when sprinting will transition player into the aimed run(with some temporary limitations)
- Crafting: FNX45 pistol can be chambered with single round
- Crafting: Opening cans with combat knife added
- Crafting: Opening cans with machete added
- Crafting: Painting Motorbike Helmets to Black and Green
- Crafting: Waterbottles and canteens now allow pouring water between them
- Effects: Magnum revolver ejecting shells when reloading
- Effects: Magnum revolver sounds - gunshots, reloading
- Effects: Mosin ejecting shells when cycling
- Effects: New Mosin sounds - gunshots, cycling, reloading
- Gear: Improvised courier backpack added
- Gear: Machete added
- Gear: Hard hats added in various colors
- Gear: Motorcycle Helmets have black visor variants
- Gear: Small, uncomfortable, and silly (but cute) children's school backpack
- Gestures: Clapping Gesture added, default F5 key
- Gestures: Pointing Gesture added, default F6 key
- Login: Player queuing system introduced. Penalty waiting time added for switching server or disconnecting a server quickly
- Login: Players receive a login timeout when disconnect, increased if disconnect within 30 minutes of joining (max 5 minutes)
- Login: When players logout, their avatar sits on ground for 30 seconds. Players must make sure they logout somewhere safe
- Server: Player spawns now cached by engine directly, increasing performance
- Server: Optimized synchronization and transfer of variables within and outgoing from server (significant performance increase on server, of 5-10 FPS)
- Spawns: Added Bubble goose jackets into the loot spawns
- Spawns: Added SKS rifle, speedloader, ammunition piles and boxes and SKS bayonet into the loot spawns
- Spawns: Healthcare Center now spawns loot
- Spawns: .45acp box of 25rnds added to loot spawns
- Spawns: Police stations now spawn loot
- Systems: Hunger and Thirst slightly modified.
- Systems: Notifications added to UI for hydration and high energy
- Systems: Fractures can now occur due to melee and shot damage, not just environmental
- Systems: Fractures (arms/legs) now saved and loaded correctly from database
- Translations: Added strings for all consumable items (Gas canisters, Batteries etc) and container items (First aid kit etc) for English, with some Spanish and Russian
- Zombies: Different types of Military zombies now have tougher attack values and improved durability
- Zombies: Engine dynamic obstacle checking (zombie, another player)
- Zombies: Svetlojarsk zombie spawns added
Fixed:
- Actions: morphine injection can be used on other player effectively fixing his broken legs and item correctly positioned in hands
- Actions: Keys won't disappear after uncuffing
- Actions: loading ammo works for sprayed Mosin variants
- Actions: Read/Writing notes with paper and pen now works again
- Actions: reviving with epinephrine or defibrillator works also if player blood is below 500 units of blood
- Actions: Actions on another player no longer have an unlimited distance (max 2 meters)
- Art: Bug allowing players to clip through geometry of the police station building.
- Animations: fixed an issue where reload in prone would leave some residue sound clutter at the end of the reload animation
- Animations: Weapon reloading for magazine was not working properly when no magazine fitted
- Animations: Rifle Aimed Walk Updated, diagonal animations fixed
- Animations: Sidestepping through doorway with rifle while crouching should not cause the player to get stuck now
- Animations: knocking down player now possible in prone states, (possibly fixing the issue with frozen characters)
- Animations: changed animation for equipping the compass
- Animations: Proper animation played when taking pistol in run
- Animations: Changing stances is faster now both for armed and unarmed player
- Animations: Skinning problem with armored zombies that caused the model to warp during some animations
- Animations: Standing with aimed weapon now allows for higher angle of tilt/bend
- Animations: Mosin bolt animation after each shot updated to match hand animation
- Animations: Removed footstep sound from pointing animations
- Animations: Pointing gesticulation now possible even when holding 2 handed weapons
- Animations: Clapping now possible to initiate while holding 2 handed weapons
- Config: Berries have more nutrition now
- Crafting: You can no longer saw off sawed off shotgun
- Crafting: Can spraypaint M4 to green or black
- Crafting: Damage is now transferred when items are painted
- Crafting: Improved Backpack creation only possible when Courier Bag is empty (previously items accidentally deleted)
- Crafting: Weapon cleaning kit can't be used when it's "Ruined" and won't reduce condition of a gun
- Crafting: Spraypainting an M4 won't delete your carry handle
- Crafting: Guns are no longer placed on ground while being painted (if not nescessary)
- Crafting: You won't loose attached universal weapon flashlight after M4 painting
- Items won't longer appear on ground after unsuccessful force feeding/drinking/fibrillating/handcuffing and won't loose quantity
- Effects: Dazed effect plays again when a player is hit/damaged/shot
- Effects: Some effects were not active locally when a player was restrained
- Effects: gunshot sound of Magnum reverted to original one
- Fixed: Missing texture error dz\weapons\data\weapons_damage_metal_smdi.paa
- Fixed: Popping up texture error for beret models
- Gear: Spraycans won't deplete after relogging
- Gear: Book, radio, pot, pan, gas canisters, matchbox, paper, firewood and stone can be placed in hands
- Gear: Headlamp beam raised slightly
- Gear: Painted items now retain their previous quantities (i.e. Magazine ammo won't reset)
- Gear: Various item descriptions and notifications fixed for grammar, typos, more detail
- Gear: ZSh-3 Pilot helmet fixed and updated
- Gear: Hoxton and Dallas masks where displayed in center of character, now display on face
- Gear: Splint position in hand was wrong now corrected
- Gestures: Taunt defaults correctly to F4 key
- Graphics: "god rays" could cause overloaded post-processing and graphical corruption
- Graphics: fix of removing shining object from hand (switch off)
- Graphics: Roads have per pixel lights
- Graphics: Dynamic lights should be now defined with "radius" value which is maximum radius of light in meters
- Graphics: Tooltips are now not displayed for quickbar items, as it is a reference to type not specific item
- Login: Respawn button now works correctly
- Login: Various bugs fixed associated with connection errors that could cause a character to be deleted or killed by the server
- Spawns: Lowered chance of Taloon and Mountain backpacks spawning
- Spawns: Drastically lowered chance of backpacks spawning on the construction site
- Spawns: Loot spawn tweaks in some civilian structures
- Weapons: Mosin recoil increased
- Weapons: Sawed-off shotgun can be loaded with ammo (was broken due to changed inheritance)
- Weapons: Sawed-off shotgun: reduced size in inventory, reduced spread
- Weapons: It is no longer possible to attach longrange scope onto SKS
- Weapons: M4 carry handle can now be attached to painted variants of M4
- Weapons - fixed error in config of shotgun snaploader causing low velocitiy and damage
- Zombies: Better filter/check of attack hits directly in engine
- Zombies: Military zombies made tougher
Hotfixed:
- Crash: Irregular crash of server in corpse garbage collector consequence of this is that the bodies will not disappear if other player is in vicinity
- Crash: Creating item using recipe system caused serious server crash when not enough space in inventory
- Crash: Client crash on exit, all systems 100% reproduction
- System: Previous build caused overzealous starvation to occur
