NZXT said:Tech Spec.
Model Number CA-S340W-W1 (White)
CA-S340W-B1 (Black)
Drive Bays External 5.25": 0
Internal 3.5": 2+1
Internal 2.5": 2
Cooling System Front: 2x 140/2x120mm
Top: 1x 140/120mm (1 x 120mm FN V2 Fans Included)
Rear: 1x 120mm (1 x 120mm FN V2 Fan Included)
Filters Front (Included)
Bottom Rear(Included)
Radiator Support Front 2 x 140 or 2 x 120mm
Rear 1 x 120mm
Clearance GPU Clearance With Radiator: 334mm
GPU Clearance Without Radiator: 364mm
CPU Cooler: 161mm
Cable Management: Lowest Point - 17mm; Highest Point 168mm
Dimensions 200mm x 445mm x 432mm
Material SECC Steel, ABS Plastic
Motherboard Support Mini-ITX, MicroATX, ATX
Expansion Slots 7
External Electronics 1 x Audio/Mic
2x USB 3.0
Product Weight 7.05 kg
UPC 15671012111 (White)
15671012128 (Black)
USB 3.0 Ports 2
Warranty 2 Years
