New PC 5 years on...!
Hi there,
In 2019 I bought a computer from PCSPECIALIST and I'm looking to treat myself to a new one. At the time, I got advice from this community and others, which was really helpful, as my original build wasn't overly balanced, so I was able to make some tweaks. The spec comes out at about £1,500, happy to go nearer £2,000 if it makes sense to!
I thought I would post my original (2019) PC and the one I am looking to purchase soon. I'm not very technical, so would be good to understand if this is a good upgrade, or if I should swap some things around. I use my PC significantly to work (nothing too intensive) and game frequently a mixture of new and old games, such as Helldivers 2 and League of Legends. I'm also due to get a Dell UltraSharp 40 Curved Thunderbolt™ Hub Monitor - U4025QW.
My current PC is getting a bit hot when I try and play newer games at their best graphics and occasionally lags. I've also looked at the pre-built machines, for e.g https://www.pcspecialist.co.uk/computers-for-next-day-delivery/1673/ and trying to understand the differences (whether the 2024 spec below is better, not much in it).
Thanks in advance!
NEW SPEC 2024:
COOLERMASTER HAF 500 ARGB
Promotional Item
Intel® Core™ i7 20-Core Processor i7-14700 (Up to 5.4GHz) 33MB Cache
GIGABYTE H610M K DDR4 (mATX, LGA1700, DDR4, PCIe 4.0)
32GB PCS PRO DDR4 3200MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP, LHR
Graphics Card Support Bracket
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler
Microsoft® Edge
Welcome Book
PCSpecialist Welcome Book
OLD SPEC 2019:
THERMALTAKE V200 TEMPERED GLASS RGB EDITION GAMING CASE
Intel® CoreTM i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB
32GB Corsair VENGEANCE DDR4 2400MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 2070 - HDMI, 3x DP GeForce - RTX VR Ready!
500GB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 16MB CACHE
2nd Storage Drive
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
32GB Hard Drive Onboard (eMMC)
CORSAIR 550W VS SERIESTM VS-550 POWER SUPPLY
INTEL STANDARD CPU COOLER
Kingdom - English Language
Ekans2011
Hi there,
Thanks in advance!
NEW SPEC 2024:
Promotional Item
Microsoft® Edge
Welcome Book
OLD SPEC 2019:
2nd Storage Drive
Hi, the pre-built system is really awful, as is yours unfortunately. 😞
Moreover, neither of them can support the resolution of the mentioned Dell monitor (is there any specific reason to buy that monitor?).
The £2000 budget is quite tight for getting a suitable dGPU that can handle such very high resolution gaming experience.
This is the bare minimum to meet your budget, providing you can transfer your OS licence and do not require NVIDIA technologies (DLSS, RT, or FG).
20GB AMD RADEON™ RX 7900 XT - HDMI, DP - DX® 12
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Firefox™
Price: £2,015.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/z0kU4WThMg/
Thank you @Ekans2011 - that's helpful. RE: monitor, I've been looking to buy an Ultrawide for some time, and have been comparing LG/Samsung/Dell and after watching/reading reviews, opted to go for the Dell.
Ekans2011
I understand; there's nothing wrong with having an ultrawide, but keep in mind that the PC and monitor must match each others or you'll spend thousands of pounds and never have a balanced and functional system.
Why not consider a 1440p ultrawide? I believe this would be a much better, more affordable choice.
Would it work with the Dell UltraSharp 40? Looking at the manual it seems it would but not sure @SpyderTracks
That's not a gaming monitor, you realise that? It's designed for graphics work, editing. The price of it is because of colour accuracy and connectivity mainly in the Apple ecosystem.
It's completely useless for what you described as your uses?
Maybe I'm missing something?
Thanks @SpyderTracks , yeah it'll help me with my work, gaming is an extra thing to do in the evenings, I was reading comparisons to other Ultrawides and the general consensus was it seemed a decent pick for hybrid of work/professional/gaming - but I am looking at the other monitors recommended above as they may be better suited
So that would suggest then that you haven't outlined what the PC is for, so we'll need to go back to square one?
"I use my PC significantly to work (nothing too intensive) and game frequently a mixture of new and old games, such as Helldivers 2 and League of Legends." was in the original post - the ability to play modern games with high quality graphics but also work on it significantly, which isn't overly intensive, so for a display I'm looking for something that does a good job at both, and reviews I read suggested the Dell did just that. I shall keep exploring the other monitors!
Yes but “work” doesn’t mean anything to us.
Must be something graphical if you’re willing to pay £1000 premium for a mid range IPS monitor simply for colour accuracy. An equivalent monitor without colour accuracy would cost about £400
Bit without knowing the suites you’re working with, it’s rather difficult to know the requirements behind it?
I’m trying to prevent history repeating itself.
Youre here because you’re having to replace a poorly designed system after only 5 years. If you’d taken the advice we offered back then, at this time you could have simply upgraded the cpu and gpu and had a top tier experience again to last you another 5 years.
Without concise understanding of budget and useage, you’ll end up with another unsuitable build.
That’s in no one’s best interest
