New PC - Berserker 2
llama
Good evening everybody!
After 12 working days I have finally received my PC this Wednesday (specs posted below).
After receiving it I have mounted an AMD 6600 waiting for the new series to come (the only cables disorganised ;)). I already positioned the second 8 pin for when I will change the GPU!
I also see that they have mounted an exhaust fan on the back which I don`t think came with the case, but that it always help!
The PC came with Windows 11 already installed without license. I have used my OEM key of Windows Professional and it worked like a charm, I did not even reinstalled the OS as everything seems to be working fine.
The CPU coolers cables seems to be very close to the GPU, but I believe it should be fine as they surely are made to endure high temperatures?
At the moment I have launched Dragon Quest XI and it seems to be working fine!
Also finally the weekend has arrived so I might have some time to test it!
The CPU seems to be a best, but will it be able to run Crysis? ;)
Special thanks for the users that helped me changing a bit the initial configuration.
For the RAM speed I was actually asked to change it to 3200MHz from PCSpecialist as I was told that the 3600MHz has issues with the 13th gen on the Z690. Hopefully it won`t change much.
Intel® Core™ i5 14-Core Processor i5-13600K (3.5GHz) 24MB Cache
GIGABYTE Z690 AORUS ELITE DDR4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
Corsair iCUE H100i RGB PRO XT Hydro Series High Performance CPU Cooler
ASUS PCE-AX3000 Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
