New Top Performance Gaming PC Specs
jacwat
I'm buying a new gaming pc and was just checking that this can play all games at top graphic levels my budget is at max £1,600.
Case COOLERMASTER HAF 932 FULL TOWER GAMING CASE
Processor (CPU) Intel® Core™i7-2700k Quad Core (3.50GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® SABERTOOTH P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, THERMAL ARMOR!
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Graphics Card 2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 2TB WD CAVIAR GREEN WD20EARX, SATA 6 Gb/s, 64MB CACHE
2nd Hard Disk NONE
RAID NONE
SSD CACHE DRIVE NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Processor Cooling TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Network Facilities ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16)
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire & Video Editing NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Office Software NO OFFICE SOFTWARE
Monitor IIYAMA E2773HDS 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080 (£229)
2nd Monitor NONE
DVI-D & HDMI Monitor Cables NONE
Eyefinity / GeForce 3D Vision NONE
Keyboard & Mouse LOGITECH® G510 GAMING KEYBOARD WITH GAMEPANEL™ LCD (£84)
Mouse NONE
Speakers NONE
Webcam NONE
Headsets (VOIP) NONE
Surge Protection NONE
Cable Tidy NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
Home Installation NONE
Data Recovery NONE
NMEBowen
Master Poster
personally for that type of money id go for the ASUS® P8Z68-V motherboard and get a cache drive aswell as swapping out the cavier green for a cavier black increasing the working speed of your pc dramatically.
jacwat
Thanks for the suggestions but this takes me over budget by £150 so i was wondering what could i scale down that wont overly effect the performance.
NMEBowen
Master Poster
drop the ram down to 8Gb you dont really need 16 most would suggest you only need 4 Gb but 8 should be perfect.
NMEBowen
Master Poster
the 2700 k could be dropped to the 2600k still an amazing chip but its not brand spanking new like the 2700k.
jacwat
Anything else i could lower
Processor (CPU) Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
Memory (RAM) 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT)
Memory - 1st Hard Disk 2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk NONE
3rd Hard Disk NONE
4th Hard Disk NONE
RAID NONE
SSD CACHE DRIVE 20GB INTEL® SSD 311 SERIES - CACHE DRIVE FOR SYSTEM / 1st HDD
TV Card NONE
2nd Monitor NONE
3rd Monitor NONE
4th Monitor NONE
Mouse NONE
Speakers NONE
Webcam NONE
Cable Tidy NONE
Printer NONE
NMEBowen
Master Poster
nope not really unless you plan to use a rj45 cable for your internet(ethernet cable) you can drop the wireless pci card (cable is much better anyway) and if you dont need it you can drop the keyboard and get a razer keyboard for 35-65 quid depending on what model you want.
NMEBowen
Master Poster
there or there about and in 12 months you can always buy a 2nd RADEON™ HD6970 and crossfire it greatly increasing gaming performance again
sharplucas
I have made a spec for you but it does not include any accessories but this is Much better for gaming and you will be able to max out absolutely anything but with the One 6970 Im not sure you can max out everything. it costs £1623
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
2nd Graphics Card
80GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 90MB/sW)
1TB WD CAVIAR GREEN WD10EARX, SATA 6 Gb/s, 64MB CACHE
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£162)
Quantity 1
NMEBowen
Master Poster
stick with the propesed spec you posted the cache drive will have a much better life than the 320 series ssd`s but i must say something i forgot if you do plan to add a 2nd gpu at a later date you would need a larger psu which is better to get now rather than buy one later as you will most likely have to rma it to get the psu fitted.
jacwat
So this is my final build i decided to go for a 24" screen which lowered the price.
2nd Hard Disk NONE
3rd Hard Disk NONE
4th Hard Disk NONE
RAID NONE
Power Supply CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£86)
TV Card NONE
Monitor IIYAMA E2473HDS 24" LED WIDESCREEN, 2 HDMI/DVI-D 1920x1080 (£159)
2nd Monitor NONE
3rd Monitor NONE
4th Monitor NONE
Keyboard & Mouse NONE
Mouse NONE
Speakers NONE
Webcam NONE
Cable Tidy NONE
Printer NONE
Data Recovery NONE
Build Time Standard Build - Approximately 10 to 12 working days
