Not sure about Motherboard choice
DJG
Hi everyone, preparing to buy a gaming desktop and I've got the following
FRACTAL NORTH TG GAMING CASE (BLACK)
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE DDR5 5200MHz CL40 (2 x 16GB)
16GB GIGABYTE RADEON™ RX 7600 XT GAMING OC - 2 x HDMI, 2 x DP
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
External Hard Drive
4TB Seagate Expansion External HDD, USB 3.0, Black
2 x 120mm PCS Black Case Fan
ONBOARD 2.5Gbe LAN PORT
Firefox™
Surge Protection
6 Socket 2m Surge Protector
Price: £2,105.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/WnEXB8YkTw/
I'm pretty happy with most of the specs but I'm not sure how to choose a motherboard, I don't really know anything about them and just picked one that seemed suitable for the other components. Can anyone see anything wrong here? My budget was £2k so slightly over but I can stretch it a bit, would be nice to get it lower if possible though. Thanks in advance
DJG
One I haven't bought yet but probably 1440p. I would add one to the order but I need a touchscreen one and PCS don't seem to do them.
Ekans2011
Several areas of the build are subpar for a decent 1440p gaming system: 5200MHz RAM is quite slow, the GPU is barely adequate for a 1080p PC, the cooler is simply insufficient for a 9800X3D, and the 850W PSU leaves little room for future upgrades.
I honestly don't know of a suitable touchscreen monitor for a gaming PC. What's your budget for the monitor?
DJG
Having the touchscreen is more important to me than whether it counts as a gaming monitor by whatever metric that is judged here. The real question was about the motherboard, which is the bit I don't understand.
How have you judged the cooler insufficient? As far as I can tell it's rated for the max TDP of the processor. (Genuine question if it looks like it's not)
It's not just the motherboard though.
We need to know what monitor you're using as that will dictate the GPU.
But the rest of the build is not suitable either, the system needs to balance all the way through, otherwise doesn't matter how much you spend, you'll only get the performance of the weakest component.
If you're just getting a basic touchscreen monitor without variable refresh rate and stuck at 60Hz, it will be a very poor experience, screen tearing will be unavoidable among other issues like serious ghosting etc. 60Hz these days would not be considered high enough for games.
DJG
Yeah I understand that so I guess the answer is I haven't actually picked a monitor yet but it needs to be touchscreen. Budget is up to £400 I suppose. I would like to know what 'touchscreen gaming monitors don't exist' means though, you can get a 27inch 100hz 1440p touchscreen monitor on amazon for £200 right now, does that not count?
As already asked, without a link we have no idea what this monitor is.
Forgove me for questioning, but there’s no such thing as touchscreen gaming. The reason I say that is perhaps you’re wanting touchscreen for windows control but not gaming itself in which case it would make far more sense to have a dual monitor setup with a decent primary gaming monitor and a secondary touchscreen
If we understand your requirements better we can advise better
Ekans2011
TDP is nothing; it is simply marketing, comparable to fuel consumption in cars; the 9800X3D has a maximum power draw of 160W, and the unknown PCS-branded cooler is utterly incapable of cooling that chip.
A 9800X3D requires at least a Premium 240mm AIO (such as Corsair) or a premium air cooler (such as Noctua), which is not available on PCS.
That's not suitable for gaming: the minimum recommended refresh rate for gaming is now 144/165Hz.
The response time is also important: 3-5ms is very high for gaming purposes.
Ekans2011
I need the touchscreen for other things I would use the machine for
I'd suggest taking a look at this thread and adding relevant information to get the best advise for your needs.
The monitor doesn't support variable refresh rate either so wouldn't be very good for gaming generally, it's more suited to video playback and general windows navigation touch.
As @Ekans2011 has linked above, if you can answer the questions, we need to understand things better to be able to give suitable advice.
