Nova shutting down under load
mrlip
Hi All
Purchased a Nova last July which has been running absolutely great until this week when it has started to shut down when under any sort of load. For example playing RDR2 or running a Heaven benchmark, it will shut down after a minute or two at most. It does not appear to be a temperature issue, both CPU and GPU are no higher than 80 when the shutdown occurs.
Once the shutdown happens, it wont turn back on for around 10 seconds and then when it does, it doesn't recognise that the power brick is connected and indicates its on battery. In order for the power brick to work again, I have to unplug the AC lead (wall to brick lead) and plug it back into the brick, then the laptop picks up power again. HWInfo64 is also reporting some Power Reporting Deviation in the red.
When benchmarking, and occasionally in RDR2, just prior to the shutdown the FPS dip massively to around 5-10 FPS and I've noticed on HWInfo64 that when this occurs, CPU Package Power dives as low as 3W.
Potential faulty power brick?
I've tried to run benchmarking without the power brick connected to rule it out but whilst I can get the CPU to run at max power using the AMD Ryzen high performance plan, I cant get the GPU to run at max power even when setting "Prefer Maximum Performance" on Nvidia control panel, it won clock past 1200mhz so isn't really an accurate test.
Specs below -
Nova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Nova Series Detachable 4 Cell Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
15" NOVA SERIES UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
INTEGRATED 1MP HD WEBCAM
Promotional Item
Get Assassin’s Creed® Valhalla with select AMD Ryzen CPUs
Welcome Book
mrlip
Yep complete shutdown and loss of power. Only warning it’s coming is the few seconds of slowdown beforehand. Sometimes Heaven benchmark will last 45 seconds, other times it will go after 10-15 seconds!
It is odd, certainly.
Have you applied any undervolt to the CPU at all?
I would try uninstalling HWInfo fully, and any other monitoring software as they've been known to conflict and give false readings on Ryzen.
Just use Ryzen Master to monitor temps and power draws, I believe you can log it to a file, maybe worth doing that just to fully rule out temps firstly.
mrlip
Yes I have ran with an under volt previously up to now when gaming however I’ve tried it at stock settings and same issue.
yeah I think RM can log to a file although it doesn’t log GPU temps as far as I know. Will run a benchmark again later and log RM readings to a file to try capture everything
That may tell us more, although I think the data you've got already is certainly telling.
After this we can target the GPU separately just to see what that's doing.
mrlip
I'm struggling to find how to enable logging in Ryzen Master, can't seem to find the option. So I ran another Heaven benchmark at stock CPU settings with HWInfo64 enabled and it shutdown after 20 seconds or so. Attached is the CSV log (renamed extenstion to .txt for upload).
EDIT: I've also noticed that after shutdown, when I restart, Ryzen Master shows the PPT as 28W rather than the normal 88W. I have to reboot again for it to show 88W
Have you got the csv?
mrlip
Oops attached now! Just to add as well, when using the laptop for browsing\downloading there is no issue, i was on it for 2 hours earlier without a problem. Its only when its under any sort of load.
  • HwInfo64Log.zip
mrlip
After some further testing earlier, I ran a cinebench R23 multicore test absolutely fine. Obviously that type of test uses primarily the CPU only.
So that would seem to point to either an issue with the GPU or an issue with the power brick when both CPU and GPU are drawing high power.
are there any benchmark tests that stress GPU only? I will try that to see if I can isolate it further
djsubtronic
For GPU stress test use Furmark.
mrlip
Ok starting to get somewhere now I think :)
As soon as I start a Furmark GPU Benchmark - QHD Preset test, the laptop loses AC power connection and switches to battery. In order for it to recognise AC power again, I have to unplug the wall plug to power brick lead and plug it back in.
Hmmm.... that's pretty conclusive then.
What are the temps on the GPU?
From and including: Wednesday, 1 July 2020
To and including: Sunday, 9 May 2021
RESULT: 313 DAYS​
It is 313 days from the start date to the end date, end date included.
Or 10 months, 9 days including the end date.
your still in warrenty so thats a good thing that silver package really is a good buy :D
i am not sure on the open case policy of a laptop but may be worth checking if there is any bulging capacitors
tho that should be after the gpu has been troubleshooted as its more likely that
mrlip
During the Furmark test, GPU temps never go above 50c - because its losing AC Power, it won't push the clock past 1200mhz so temps never rise. I get a whopping 11FPS during the Furmark QHD test because its running on battery :) If I run a heaven benchmark, as mentioned that will lead to a shutdown and highest GPU temp is 64 before it dies.
I have just spotted that on the heaven benchmark, it is also losing AC power which is when the stutters start. It doesn't lose AC power straight away like Furmark,but after 20-30 seconds or so, it drops AC power, stutters for a few seconds then shuts down.
Think I should contact PCS, link them to this thread and request a new power brick is sent out?
And yes Jamie, the silver warranty really is worth the extra few quid it seems! That was a recommendation by SpyderTracks at the time :)
Yeah, I think that's one for PCS, something very odd going on there!
mrlip
Yeah that is what I am thinking, hopefully its just a bad AC brick rather than the GPU. I will raise a support message to PCS. Think first solution would be to try a new power brick unless they suggest otherwise. I nearly bought a spare when I got the laptop but decided against it - wish I had now! :D
I will message them now and keep this thread updated with progress in case others have a similar issue in the future.
