Old Lady No Longer Booting
Hi there, throwing a hail mary pass here and hoping someone might be able to help. 11 year old PCS computer that has served me exceptionally well has seemingly breathed her last. I had been starting my research on purchasing a new one later this year and I believe everything important is backed up but wouldn't mind getting her running one last time to be sure. Clearly she's well past her best so I don't want to be spending anything on it as that would also impact my budget on the new one.
Issue - not booting. Power comes on when button is pressed. No 'beep' to signal POST has been completed, no power to USB mouse or keyboard, the mouse has LED lights inside that usually light up whenever it's moved and it works fine on wife's laptop. No signal to monitor (checked and monitor works with PS4). All internal fans working including on CPU and GPU. It does appear to try to access the DVD drive as that is whirring away with no disc inserted, tries this 5-6 times before giving up. You can usually hear the HDD making some noise on boot but it's more or less silent.
Specs are -
COOLERMASTER ELITE 430 BLACK CASE
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
ASUS® M5A97 (DDR3, USB3.0, 6Gb/s)
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB NVIDIA GEFORCE GTX 760 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card
NONE
3rd Graphics Card
NONE
500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
2nd Storage Drive
NONE
RAID
NONE
2nd DVD/BLU-RAY Drive
NONE
External Hard Drive
NONE
NONE
STANDARD AMD CPU COOLER
Fan Controller
NONE
NONE
Wireless Router/HomePlugs
NONE
4G Module
NONE, I WILL BE USING BROADBAND
Firewire
NONE
TV Card
NONE
The GPU was replaced in Feb 2018 with a GTX 1050TI and I installed an additional 8GB RAM chip 3-4 years ago with no issues on either in the meantime. I have also plugged in an older 250gb SATA III internal hard drive many years ago with no issues. Windows was updated to 10 a long time ago.
My amateur suspicion is the motherboard has given up, there were no noticeable issues leading up to the current problem. I've tried booting with just one of the two RAM chips in place but neither of them made a difference, I've tried removing the CMOS battery for a period of time to reset any BIOS settings and also replacing it with a new one to no avail, the 250gb HDD has Windows 7 installed as far as I can recall and unplugging the main HDD drive to boot from it didn't make any odds although I may have disabled this option from BIOS a while back. As mentioned it seems to be trying to access the DVD drive but disconnecting that from the MOBO makes no difference either. Also tried flushing the power out by unplugging everything and holding the power button.
If anyone has any further suggestions to try then I'm all ears! One final question would be regarding more modern motherboards, would I have any issues plugging the HDD drives (assuming they still work of course) in to something like the ASUS Prime X870 mobo for example just to grab any data and to format them?
Ekans2011
This would not be an issue, but the system posted above is so outdated that it's incompatible with any modern hardware. If your motherboard is dead, I believe there is no choice but to get a new PC.
Oh I fully expect there's nothing to be done getting this one working and certainly not looking to spend anything on it, posted purely in the hope of someone having a light bulb moment to resuscitate it!
Ekans2011
Much appreciated but unfortunately didn't work, so I'll accept the inevitable and get on with buying a new one. Next stop will be the 'check this spec' sub-forum!
Well, it served you for over 10 years, which I believe is an excellent lifespan. :)
Don't forget to look at the below when you decide to start a new ''check this spec'' thread ;)
