Hi guys, I'm looking for some advice on which monitor to buy.
I can't decide between the BenQ XL2411Z or the Asus VG248QE, I like the look of the BenQ but the Asus has a Display Port which I like.
Can anyone recommend any of these monitors or any others that fit in a budget of around £200-£250 and has a refresh rate higher than 60hz, the rig they will be used on has a 980ti.
Thanks for your input.
