Optimus pro Xi Drivers?
PaoChi
A part those in the standard link, there are:
- a decent driver for the touchpad?
- a most update drivers (coz the given one are April 2020...)
Are you having issues with the touchpad?
Can you post your FULL spec from the order please?
1dogman1
As a new owner of the Optimus Pro XI the touchpad driver package also confused me.
When downloaded it has an attached pdf that suggests the drivers are Pixart, although it installs as "Hid compliant mouse"
It works as I would expect a touchpad to work so no big issue.
I looked on the XMG site for the core17 and it has an updated Bios (which I will not be installing) that includes a Pixart update.
It could do with some sort of explanation from PCS as to what is needed.
  • Update Flash Driver 安裝方法_20191009.pdf
