So I finally decided to wait a bit and get my new laptop after I move to the UK, from PCSpecialist. I am between getting the Optimus V 13.3 vs the Optimus V 15.6.
As far as components are concerned I'm settled on these:
i7 4710MQ
860M
1x8GB
Cheapest HDD possible
I am strongly leaning to the 15.6 (Clevo w350st) for these reasons:
1) A 2nd HDD slot where I can put my desktop SSD and not completely throw away the HDD I'll buy
2) Bigger screen for movies
3) SPDIF out (might come handy, i'm kind of a good sound guy)
4) Better temps because bigger? No?
But the 13.3 Optimus V (Clevo Clevo w230st):
1) Better mobility
2) An IPS screen (even the regular 1920x1080 one is stated to be IPS). From what I can tell the 15.6 doesn't have one. From what I gather this is a better image quality and viewing angles, but more latency? Is there a big difference?
3) Cheaper
4) They let you put a Kingston HyperX Impact RAM instead of normal Kingston, don't know if they are faster or just lower temps.
It all comes down to the cases themselves. I don't mind paying the extra quid for the bigger screen, but if it is worse looking it is going to be a bummer.
My questions are as follows
1) Is the IPS screen worth it, even if it is smaller? Can you order the 15.6 with an IPS screen? If not, how is the normal 15.6 screen? Any impressions?
2) Why can't I order the RAM to be dual channel for the 15.6? I see in the specs that it has 3 RAM slots. And also why don't they let you choose the Hyper-X Impact Kingstons? (only 3 gbp more)
3) What is the difference between the various wireless cards? Is it worth it spending the money on the better ones? Is there better signal reception, or is it only a matter of larger bandwidth?
4) What do you guys think on my dilemma? It will be my only PC while in the UK and I will be working quite a lot on it, watching movies, apart from games, I will be spending tons of hours I imagine on it. That is why I think the bigger screen is better, but I don't want it to be **** :/
5) Finally, a logistics question, can I order the laptop before I move to the UK, without knowing where I will rent a flat, and without knowing the exact adress? I don't want to be 2 weeks with no PC when I arrive!
Thanks!
i7 4710MQ
860M
1x8GB
1) Better mobility
3) Cheaper
Thanks!
