xSoulShadoWx
I turned my PC on tonight and as usual it went through it's post boot check and I was greeted with 1 long beep and 3 short beeps and no display on the TV which usually displays the PCS logo as it boots into Windows 11. I powered the PC down and tried again as I've had it fail to boot before occassionally in the years that I've had it but after a power down and restart it this had usually fixed any glitches. Tonight was however different as the same error beeps occurred. I've googled this and it looks like it could be a GPU error.
Anyone have any suggestions before I need to return it back for checkup and repair if needed?
CORSAIR iCUE 465X RGB GAMING CASE
Intel® Core™ i9 18 Core Processor i9-10980XE (3.0GHz) 24.75MB Cache
ASUS® ROG STRIX X299-E GAMING II: ATX, USB 3.2, SATA 6 GB/s, Wi-Fi AC - ARGB Ready
24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
ASUS PCE-AX58BT Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz + BT 5.0
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Windows 10 Professional 64 Bit
