Does seem to be working but going through to answerphone.The phone line seems to be down.
Is there another number I can try?
+44 333 011 7000
Moose signal received.Does seem to be working but going through to answerphone.
I have notified them on the batphone, will update you when I hear more, thanks for raising it![]()
Thanks for the updateMoose signal received.
We are sadly incredibly busy but we are expecting the phone lines to quieten down over the next hour or so. I would recommend ring back then and you should be able to get through.
