power cuts on my new 4k rig
casper007
Hi Everyone
I bought a pc from this place last week and for some strange reason at max settings playing cod aw with my 4k monitor.
With 5.1 audio the power cut out what is the problem,
CORSAIR OBSIDIAN SERIES™ 750D FULL TOWER CASE
Intel® Core™i7 Six Core Processor i7-5820K (3.3GHz) 15MB Cache
ASUS® X99 DELUXE: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
32GB KINGSTON HYPER-X PREDATOR QUAD-DDR4 3000MHz X.M.P (4 x 8GB)
12GB NVIDIA GEFORCE GTX TITAN X - DVI, HDMI, 3 X DP - (PRE-ORDER ONLY)
1st Hard Disk
500GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE)
Corsair H60 Hydro Series High Performance CPU Cooler
ASUS Xonar D2X - Masterpiece Audio Card for Home Theater
Genuine Windows 8.1 Professional 64 Bit - inc DVD & Licence
Windows 10 Upgrade
FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
DVD Recovery Media
Windows 8.1 (64-bit) Professional DVD with paper sleeve
Monitor
ASUS 28" Professional 4K PB287Q
steaky360
Hi, Welcome to the forums!
Did the power cut out to the entire rig (ie it just switched off??) or did the audio cut out?
Does the problem repeat itself (ie have you tried playing COD @4K max settings & 5.1 audio)??
casper007
Thanks for replying.
The rig shut off completely and rebooted i was like what the.
I have not retried it in fear it will damage the rig.
steaky360
Its entirely possible it could have been an isolated incident - have you used the rig since? If it has not happened again then its worth trying to play the game again to see if the problem re-occurs.
Alternatively, you should try some benchmarks etc (GPU, RAM and CPU - google can find suitable ones with ease :)) really just to stress the pc a bit and see if it reoccurs.
casper007
I have turned it on like usual for emails and so forth.
Not had the time to run it again.
I will report back later. Also what benchmark do you recommend on google.
Many thanks
Matthew
casper007
I tried again this morning seemed to be fine
Turned down the megahurtz to 60 and 75 on cod.
Bought a surge protector.
Also ran 3d mark demo edition on it as well cant run 4k demo as its not free.
Thanks for your concern.
