yeah that's a fold out USB, and looking on the back of it, it has the huge capacity of....................................128MBDon't recognise it. Is that a fold-out USB connection on top?
My last piece of catalogue work (in 2010) ended up being over 100GB, so I think I'll stick to a portable SSD.yeah that's a fold out USB, and looking on the back of it, it has the huge capacity of....................................128MB
Yeah I've got a caddy in my laptop bag that's got a 1TB M.2 in it that just plugs into USB C port, Its got WebODM on itMy last piece of catalogue work (in 2010) ended up being over 100GB, so I think I'll stick to a portable SSD.
What size are we talking 5 1/4 or 3 1/2i showed someone what a floppy disk is, their exact words were "how can you save stuff on a coaster?"
I'm saying nothing...🤭We used to use 8” floppy disks with our IBM System 36 machines. It was 50/50 on whether you’d bend it trying to get it into the drive![]()
Punched paper tape was even slower.I'm saying nothing...🤭
The company I was at switched from punch-cards to disks about 6 months before I joined. Otherwise it was a 2-day turnaround to see if your code ran without errors.Punched paper tape was even slower.
When I did CSE computer studies at school in the mid 70's we used to code cards in basic, using a "B"grade pencilThe company I was at switched from punch-cards to disks about 6 months before I joined. Otherwise it was a 2-day turnaround to see if your code ran without errors.
I was in the Royal Corps of Signals, from '79 - '91, as a Combat Driver/Storeman. In the field I drove an ESV, a 4x4 Bedford truck with a big generator mounted on the front half of it's flatbed, and a 10' box mounted behind that. Inside the box was my office space and £1.5 million of solid state circuit boards, several hundred of them, all different. I worked in conjunction with an Electronic Repair Vehicle, driven by a technician. An ERV had a 20' box with a big computer in it and cables to plug any equipment into the computer for testing. The computer was run by 2 x 8" floppy drives. (Ours looked like big 5 1/4 inch discs, in the same type of waxed brown card. I'm guessing they were 8", I thought they were 12", but it was a long time agoWe used to use 8” floppy disks with our IBM System 36 machines. It was 50/50 on whether you’d bend it trying to get it into the drive![]()
