Hey ive ordered a desktop from here and its on testing stage. The pc requires 622w and ii have 650w psu.
Will it crash im not oc im just gaming and editing
ontop of the 20% buffer PSC build into the configurator you also have the fact that the maximum wattage figure means you would be running everything 100% at the same time.
You would not be doing that unless you were burning a DVD, transferring files over USB while charging your phone while stressing the CPU and GU 100% etc etc etc. Its more than safe if your under the limit you will be fine.
