question about my pc
umar
i brought a pc i customised and it was for £1194 after applying a discount, i went to check my specs exact same and the website showed it was worth £1021 i just wanted to know if i had been overcharged or will i be paying for the price it currently is not a few hours have passed
The price is fixed at the time you place your order. Prices go up and down all the time based on availability, supply and demand. You can always cancel and reorder if you think you can get it cheaper.
umar
I just ordered it earlier this morning I wonder how long it would take to cancel and order again
I would strongly suggest your reconfigured build differs if the price difference is that much, there's likely something you're missing off the new configuration.
umar
Yeah its very strange im going to double check on my computer and update this I was stunned by the price no chance it can drop in value that much i must have missed something
umar
@SpyderTracks just double checked it exact same have emailed them see what they say as its still processing crazy i brought it at 1pm and 3pm its that much different
Can you post your original order from the order page and the new quote?
ColEyt
Both those links give the same price of £1051 inc Vat to me
Are you able post your system as per the instructions in the link below
umar
@ColEyt i followed the instructions and clicked the link it shows the same £1051 inc vat but i was charged £1194 an hour before
https://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-III/nb8CtafnXg/
followed the instructions exactly i went to my order clicked show and clicked on post specs to forum and copied the link
thats whats confusing me so much how can the price be so different in an hour or did i get an incorrect price valuation i have emailed them see what they say very unclear as to what happened
JUNI0R
It sounds like you were just unlucky with timings. To deal with it sooner, I'd give PCS a call. Their emails are taking about a week to respond to at the moment so you could be waiting a while. You could either ask if they'd honour the new price (I'd make sure you save it as a quote on your account so you have it handy) or cancel and re-order.
Also, honestly, this isn't a very well specced system at all and there's a lot you could change. If you give us your budget, monitor info (make and model or resolution and refresh rate) and what you'll be using the PC for we'll be able to get you a much more balanced build together which you could use when you come to re-order.
Also I see you have no Windows OS in your spec, do you already have a PC you can take a key from or a legitimate copy? If not you'll have to have one included in your build.
umar
Interesting ill see if they honour the new deal prob try get in touch with them tomorrow my monitor ill be buying is a gigabyte g27qc 165 hz monitor and my budget for the pc was £1200 if you have any alternatives I'd consider cancelling and re ordering for sure I thought it would be best for my budget
Main goal for this pc was to get the best price to performance i could get
If you can post your original order specs from the order page, rather than posting a config link, it's all outlined in the thread above.
umar
@SpyderTracks this is the one i ordered the link takes this exact specs to a price of £1051
Case PCS 3601 CASE
Processor (CPU)Intel® Core™ i5 Six Core Processor i5-10400F (2.9GHz) 12MB Cache
MotherboardGigabyte H410M H V2: Micro-ATX, DDR4, USB 3.2, SATA 6GBs
Memory (RAM)16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP
1st Storage Drive512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
Processor CoolingSTANDARD CPU COOLER
Extra Case Fans2x 120mm Black Case Fan (configured to extract from rear/roof)
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
Build TimeStandard Build - Subject to stock availability on pre-order products
