mgsolidus
So I bought liquid cooling a while back - Thermaltake Water 2.0 Performer, and it is intended to be used in a push/pull configuration, but I can't do this because my case (Zalman Z11 Plus) is too small, unless I remove the top exhaust fan.
So, what I did instead was put the radiator in first so it's against the case, and then a fan behind pushing air through the radiator and out the case. Is there anything wrong with this? I realize that the fan is usually in front, but this is the only way it would fit.
Also, temperatures. Is 9c for an FX-6300 too cold? This is an idle temperature.
