Re-installed Laptop - Can't find Sound BlasterX Pro Gaming Drivers in Account
danfid
I had sever lag issues on my rig (specs below):
Showing Order Reference 1646608
Chassis & DisplayDefiance Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Memory (RAM)32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® RTX 2080 Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st Storage Drive1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
1st M.2 SSD Drive2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
2nd M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor2 x 180W AC Adaptor
Power Cable2 x 1 Metre Cloverleaf UK Power Cable
BatteryDefiance Series 4 Cell Lithium Ion Battery (62WH)
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & WirelessGIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options2 x USB 3.1 PORTS (Type C) + 2 x USB 3.1 PORTS
Keyboard LanguageRGB BACKLIT UK KEYBOARD
Operating SystemWindows 10 Professional 64 Bit - inc. Single Licence
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
BrowserGoogle Chrome™
Laptop Cooling StandsCoolerMaster NotePal L2 Laptop Cooler, upto 17.3 inch
I can't find the drivers for the Sound BlasterX Pro Gaming 360 control panel. Can you tell me which file in my account this is? I've reinstalled all of them, or so I thought. I thought it was the SBX file however I can't find the control panel after it installs.
Order No. 1646608
Also, is there updated drivers available, other than the static ones posted to my account?
Thanks for the support.
Dan
danfid
Thank you for the reply Spyder. How do I know which model is mine? My model number doesn't match any model on their website.
danfid
Spyder,
You are rocking the support. I'm very thankful.
I have two model numbers, both I have found under the laptop.
1st - Clevo black label: P970RN
2nd - White label: PC1-16466C8
danfid
Spyder,
I found it. It was a long list to go through. Thank you for the help so far. Much appreciated.
danfid
I've looked at all of the drivers for those models and there isn't anything mentioned about SoundBlasterX Pro Gaming 360. Was this an additional bit of software that PCS installed locally?
It should be in the optional category, listed as Creative driver 3_SBX.zip
danfid
I've installed and still no Creative or Sound Blaster front end application. The 3_SBX.zip file isn't in my Account laptop downloads page. I'm thinking that this is a local install. Any other help to figure this out Spyder?
What does it install then when you install it?
danfid
As far as I can tell, it is backend updates for the Windows sound control pane and EQ. There isn't any indication that a Creative application was installed.
This is the batch file contents:
Start /wait SPKEQ_CLV_PCAPP_US_1_01_70.exe
Start /wait CreativeAudioEffectsComponentInstaller_2.0.0.31.exe /silent
@Echo off
echo msgbox "System will restart automatically!" > %tmp%\tmp.vbs
wscript %tmp%\tmp.vbs
del %tmp%\tmp.vbs
Start shutdown /r /t 0
"C:\Program Files\Creative\Creative Audio Effects Component" folder is empty.
