kokabel
I suspect that my cpu heatsink fan is on it's way out, or at least I think it may be that, or one of the case fans (angry whirring noise on start up, stops after a few minutes). This is typical as I just replaced my video card because of ongoing fan issues.
May as well replace them all while I'm at it, since it doesn't look too expensive to do. I was wondering if anyone had some recommendations - I think (just eyeballing it) the cpu heatsink fan is 80mm, and the case fans are standard 120mm. I don't imagine I need to seek any specific brand, so long as they are right dimensions, is that correct? The cpu fan is held onto the heatsink via a sort of metal clip that looks easily removable, so I shouldn't have to take off the whole thing if only replacing the fan.
I quite like these... mmm, purple. http://www.amazon.co.uk/gp/product/...&pf_rd_t=3201&pf_rd_p=517831827&pf_rd_i=typ01
No idea if they're any good/what I'm looking for though. Any ideas/suggestions appreciated!
