RGB ON RAM SOLID
carlos726811
Hi There. Was wondering if anyone could help. Soon as i put my PC on everything fine all RGBS working as they should. ( RGB Set to multi colour ) But soon as i play Games. MY RGB on my ram becomes solid and all 1 colour.. I notice a triangle in the Icue software. Seee pic. What is the issue.
What does it say when you go into the RGB RAM whilst that warning is showing?
I had this problem & found a cure by searching on the web, it entailed renaming a folder somewhere but can't remember where and i can't find the post that explained it
melocolic
I have this issue occasionally. If you go into Task Manager and close the Corsair services, then restart iCue it should do the trick. I can't remember exactly what the issue was but the new iCue software created other gremlins so I went back to the original version.
