RGB software?
Hi there,
After having to reinstall Windows due to a lovely Windows bug where it would just stay looped in set up, after setup I've been stuck with the blue hue for m RGB keyboard, which during boot does change colour.
I'm just wondering what software I would need to control this keyboard?
Here is my spec:
Chassis & DisplayDefiance Series: 17.3" Matte, Full HD, 144Hz, Pantone Validated 72% NTSC, LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 14 Core Processor 12700H (4.7GHz Turbo)
Memory (RAM)32GB Corsair 3200MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® RTX 3080 Ti - 16.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive1TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W)
2nd M.2 SSD Drive1TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W)
AC Adaptor1 x 230W AC Adaptor
Power Cable1 x 1.5 Metre Cloverleaf UK Power Cable
BatteryDefiance Series Integrated 6 Cell Lithium Ion Battery (80WH)
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 + BT 5.0
USB/Thunderbolt Options1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
Keyboard LanguagePER-KEY RGB BACKLIT UK KEYBOARD
Windows Recovery MediaWindows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account
BrowserMicrosoft® Edge
Build TimeStandard Build - Approximately 4 to 7 working days
This is all I got?
DarkPaladin
If you check underneath your laptop, you should see the Clevo model number. For example, mine is P775TM1G.
  1. Open this link: https://www.clevo.com.tw/clevo_down.asp?lang=en
  2. Next to model, click the item with the serial number underneath your laptop
  3. Under driver, click "Other"
  4. Scroll down to the bottom to find the latest version of "Control Centre" (there's a tab labelled "Start" which will tell you the latest version by its release date)
