SD SDHC card readers
kencri
Hi all,
Ive noticed on quite a few of the laptop models they only have a 2 in 1 card reader (SD, MMC) So this presumably means i couldn't use my SDHC cards?
Thanks ken
kencri
SDHC cards are SD cards (HC is for High Capacity).
“Because SDHC works differently than standard SD cards, this new format is NOT backwards compatible with host devices that only take SD (128MB - 2GB) cards. ... SD Extended Capacity (SDXC™) card is an SD™ memory card based on the SDA 3.0 specification.”
???? So the 2in1 card reader isn’t compatible with my sdhc cards ?
It's compatible with all existing SD cards including XC and HC
