Slow Framerate when playing a Yogscast Complete Pack for Minecraft on my current rig
jaymeh
I have had my machine from PCS for about 2 years now and recently have started to get into playing Yogscast Complete Pack Modpack for Minecraft. A lot of people have mentioned that the modpack is quite CPU intensive and I am having some issues with my framerate being around 30fps whilst playing. I was wondering if upgrading my CPU would help to boost the performance.
The CPU I am looking at is this one: http://www.amazon.co.uk/AMD-FX8350-...8&qid=1412633882&sr=8-1&keywords=phenom+1100t
This is a last resort thing as I have tried to use things like FPS+ and Optifine but they haven't installed correctly and caused errors when launching the modpack. I have also tried running Minecraft from my SSD and checked that I am running a 64 bit version of Java.
Here are my current specs to compare it to.
Processor (CPU) AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
Motherboard ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
Memory (RAM) 8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card 2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Hard Drive Kingston SV200S3128G SSD
Thanks,
Jaymeh
vanthus
Member Resting in Peace
Are you using 64bit-Java (assuming you are using a 64-bit operating system) it can make a big improvement in the performance of Minecraft.
jaymeh
I decided to go ahead with buying it and upgrading my cpu. I am very happy with the results of it too. Almost Doubled my framerate in the modpack.
Thanks for the advice
