slow/sluggish BIOS menu
Joeyniple
When i was changing my fan setting in the BIOS, i noticed the menu was very slow/sluggish with the mouse. I have the ASUS ROG STRIX X570-F Gaming mobo. The system seems to run fine with no performance issues i can notice. Had a look at the system info and the BIOS version/date says American Megatrends inc 3404, 14/01/2021. Is this something to worry about, should i ring PCS about a BIOS update for this mobo?
For the BIOS itself to run slow there would have to be something catastrophically wrong and very unusual.
What’s more likely is slow mouse support outside of windows. Try with a wired mouse and see if it behaves differently.
NoddyPirate
My mouse is connected via USB - Mouse performance on my BIOS is slow enough to be almost unusable - delay in cursor catching up with my movements - clicks can be hit and miss - etc - which is why I use keyboard controls instead.
Using Q-fan in BIOS is tedious as a result. Which is why I use Fan Expert mostly instead from within Windows.
A wired connection might be a bit better, but BIOS is not a full OS so I consider my mouse behaviour to be perfectly normal as far as I am concerned. I wouldn't worry about it at all.
My motherboard is ASUS PRIME B550 PLUS - previous and latest BIOS version behave identically.
(P.S. Do not attempt to update your BIOS version without PCS' express permission.)
On the other hand I'm using a Logitech Logi wireless mouse and that performs as well in the BIOS setup as it does in Windows. Go figure...
NoddyPirate
It probably depends on the polling period being used I'd imagine. If the mouse is buffering it's movements quicker than the BIOS can handle them then I imagine lag will result.
Perhaps if the OP has one of those fancy mice where you can change the polling rate then it might help if they changed it.....?
NoddyPirate
Juts checked my mouse specs - it has a dpi of 1000 which is high for a basic mouse but low for a gaming mouse I suppose - can you tell what your DPI is - just for comparison?
(EDIT - I can't see my polling rate so have no idea what it is.....)
Don Coyote
I have the same motherboard and when I am in the BIOS it is also very slow like moving in treacle when using the mouse; when making selections with the keyboard then everything is quick as you would expect. I think it has as much to do with the resolution on the widescreen monitor not working too well with the BIOS output and the mouse dpi.
Dunno to be honest. The blurb says it's variable between 400 and 4000 dpi but I've no idea how you can change that. I don't game so it's never really been an issue for me. :oops:
NoddyPirate
If yer bored - it would be interesting to see if the extreme settings make any difference within BIOS. I've no idea if changing DPI would change the polling rate too.....?
A fun exercise for you for the weekend!
It's hardware innit? As I said I've no idea even how to change the DPI on that mouse. I can swap the pointer speed between two settings via a mouse button but I don't suppose that affects the DPI at all? I did just install Logitech Options (against my better judgement - and only because the upcoming 21H1 will give me an excuse to reinstall Windows) but there's nothing in there to directly set the DPI.
NoddyPirate
I think the pointer speed button is actually changing the DPI.
I just remembered I have a USB mouse for the kids computer which has two DPI settings - so I'll run a quick test later for the OP - I'm stuck in a Teams meeting at the moment so can't restart into BIOS for a while! :rolleyes:
NoddyPirate
Right - tea break in the meeting - just tried the other mouse which has 3 DPI settings on it......
......and it made no real difference at all! There goes that theory! :D However it was easier to use this mouse in BIOS than my original one - so it may be that DPI has nothing to with polling rate and polling rate might be what matters.
The OP could try a different mouse - or better yet, fiddle with BIOS so much that you learn all the handy keyboard shortcuts and sequence of key presses within BIOS so you can go into it, change something and save and exit with your eyes closed. It works for me! :)
Joeyniple
Thanks for the replies, i went into the BIOS again to have another look. I would say the mouse is kind of sluggish but not worryingly slow and not smooth like using windows but it is usable, maybe it's fine. I'm using a wired USB mouse, a Tecknet one which is about £15 so nothing fancy here. Also noticed that when i start the PC, if i dont turn the monitor power on first, i get a long beep followed by 3 short beeps after and it will boot after that and If i turn the monitor on first it's fine, no idea what that is either. Also here is the specs since i couldn't access it the other day.
CaseCOOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE
Change to: CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU)AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
Change to: AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
Memory (RAM)32GB Corsair VENGEANCE DDR4 3600MHz (2 x 16GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD Drive1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Processor CoolingCorsair H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
BrowserGoogle Chrome™
Build TimeStandard Build - Subject to stock availability on pre-order products
MotherboardASUS[emoji2400] ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
Power SupplyCORSAIR 850W RMx SERIES[emoji769] MODULAR 80 PLUS[emoji2400] GOLD, ULTRA QUIET
Office SoftwareFREE 30 Day Trial of Microsoft 365[emoji2400] (Operating System Required)
BrowserGoogle Chrome[emoji769]
The beeps with the monitor off is a well know effect and is nothing to worry about.
Joeyniple
Good to hear, it was worrying me a bit but i thought it would be something to do with not recognizing a display without the power i guess. Doesn't seem i have to worry about doing a BIOS update then, the menus change fine when i click them just the mouse seems a big laggy/slow caused by USB compatibility issues maybe? since the more recent firmware updates on the ASUS site have that in them.
NoddyPirate
I think the lag is just simply the low refresh rate of the mouse information while using BIOS. I wouldn't think it's BIOS version realted myself.
Joeyniple
Been having some issues recently with my PC. While running a game it will after a few days randomly crashes, black screen then i have to press alt tab to go to window and manually close the game then ALL games run on 1-2 fps basically unplayable and cant even navigate menus. I tried uninstalling the nvidia driver then re-installing which seems to make it normal but it happens again maybe a few days later. No idea, and my GPU usually runs at 69 degrees while gaming never really goes above that. Also i got an this error message
Also i did DDU clean install drivers and seeing if it helps now also, here are my specs:
That error is clearly related to your RTX3070. Hopefully it's just a driver error but it could potentially be a graphics card issue.
Use DDU to remove the existing Nvidia driver (it will reboot) and then download and manually install the latest driver for your card and OS direct from the Nvidia website.
Joeyniple
That's what i did today, hopefully it resolves the issue. Kind of strange how it works fine then suddenly crashes and black screen. Only when i try running games after the crash i get 1-2 fps and its unable to even load anything, but windows itself seems to run ok though
