garywood84
I am slowly working out specs for a new computer but am confused about sound cards. There are several options from Creative, but I can't find a good comparison online to figure out what the difference is and which one I should go for. I don't play games, but do use my computer to listen to music, and also to make recordings. Does anyone have any suggestions, or know where I can find a decent comparison?
Following on from this, I have a set of Creative Inspire 5700 speakers that I was intending to keep. These are 5.1, and connect to my current sound card using a single 3.5mm connector (into a socket labelled "Digital" on the sound card). I can't figure out whether this connection is still available, since several sources I've read suggest I need three separate connectors for 5.1. Does anyone know if this will work, or do I have to budget for new speakers too?
Thanks,
Gary
Thanks,
Gary
