Suggestions on upgrades or worth building whole new one?
Andykg10
Hi there.
Looking to upgrade at some point as this PC is coming up to 5 years old next early next year.
Can anyone suggest what to change please.
Thanks.
Here are my current specs:
Case COOLERMASTER COSMOS SE GAMING TOWER (Windowed)
Processor (CPU) Intel® Core™i7 Six Core Processor i7-4930K (3.4GHz) 12MB Cache
Motherboard ASUS® RAMPAGE IV BLACK EDITION: INTEL X79, SOCKET 2011, R.O.G
Memory (RAM) 16GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (2 x 8GB)
Graphics Card 3GB NVIDIA GEFORCE GTX 780 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
1st Hard Disk 240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply CORSAIR 1200W PRO SERIES™ PLATINUM AX1200i DIGITAL MODULAR PSU
Processor Cooling CoolerMaster Hyper 212 EVO (120mm) Fan CPU Cooler
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Genuine Windows 7 Ultimate 64 Bit w/SP1 - inc DVD & Licence
What are you looking for out of an upgrade? More performance, but for what?
Gaming? If so, what monitor do you use?
Video editing? 3d rendering? specific software?
For gaming the platform is fine. You could consider buying a new monitor if your old one is quite low spec, and one of the new Nvidia GPUs that are due out.
Depending entirely on budget and what you actually are looking to achieve by an upgrade / new system :)
