System crash
KriChr
Hi
every time I finish playing Fortnite and turn off the game a blue screen appears and the system resets during the game nothing happens fps 340
Is this a pc specialist system, if so then please copy and paste the full spec from your orders page, if not I'm afraid we can't help as this forum is dedicated to pc specialist customers
KriChr
Can you copy and paste the full specs from the order page on your PCS account?
What make and model monitor are you using?
PCS LUMIN ARGB MID TOWER CASE (PWM)​
Promotional Item
Promotional Code ZZ-PCS25-BFT9-376D
Terms & Conditions
AMD Ryzen 7 9800X3D Eight Core CPU (Up to 5.2GHz/104MB w/3D V-CACHE/AM5)​
GIGABYTE X870E AORUS ELITE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)​
32GB Corsair VENGEANCE RGB DDR5 6000MHz CL30 (2 x 16GB)​
16GB SAPPHIRE PULSE RADEON™ RX 9070 XT GAMING - 2 x HDMI, 2 x DP​
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)​
NOT REQUIRED​
CORSAIR 850W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD​
1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core)​
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER​
ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND APPLICATION​
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)​
ONBOARD 2.5Gbe LAN PORT​
NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)​
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS​
NO OPERATING SYSTEM REQUIRED​
United Kingdom - English Language​
NO RECOVERY MEDIA REQUIRED​
FREE 30 Day Trial of Microsoft 365® (Operating System Required)​
NO ANTI-VIRUS SOFTWARE​
Microsoft® Edge​
ASUS TUF K1 Gaming Keyboard & M3 Gen II Mouse Bundle​
KriChr
Promotional Item
Terms & Conditions
NOT REQUIRED​
Microsoft® Edge​
That error points to an issue with a Realtek network driver.
Are there any updates showing in Optional Updates for that driver? (according to Gigabyte's website, there was a driver update on 12th June)...
Also, have you installed any 3rd party 'driver manager' software (even the Gigabyte one), as they tend to offer incorrect/outdated versions.
